[AG-TECH] Windows Vic Crashing
Thomas D. Uram
turam at mcs.anl.gov
Fri Feb 6 13:42:18 CST 2009
If you run DebugView (google it), do you get any information about
badness occurring inside of vic?
Can you capture the stack trace with a screen capture?
(Shift-PrintScreen) I don't think that stack trace will be of much use
anyway, though.
How does wdmscan.exe that ships with the AG behave?
Tom
On 2/6/09 11:01 AM, Todd Zimmerman wrote:
> On Thu, 2009-02-05 at 19:33 +0000, Piers O'Hanlon wrote:
>> Hi Todd,
>> Is that a windows XP box? Do you have the latest drivers for the Ncast
>> capture card? Presumably you don't still see the dvice in the device
>> manager (if so delete it from there and try again). What colour depth
>> is your display set to - should be ok on 16 or 24, 32 bits. Are there
>> any other capture devices loaded (USB etc?) Do you get any message
>> when it crashes?
> Windows XP with latest Ncast drivers.
> Device has been physically removed and doesn't show up in the device
> list.
> Colour depth is 32 bit.
> No other capture devices loaded.
> No message when crash except attached error msg. There is a stack trace
> available if you click on the 'more info' link on the error dialog;
> however, unfortunately, there is no way to cut/paste/save the stack
> trace text from the dialog box (can't even select the text)....
> Any other suggestions??
> Thanks for all your help.
> Todd
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090206/ee0838b2/attachment.htm>
