[AG-TECH] Windows Vic Crashing
Don McLane
dmclane at u.washington.edu
Thu Feb 5 14:12:08 CST 2009
Is VMware installed on the box? If so, disable VMware's virtual network
connections. I've seen problems between VMware and VIC on two different
XP systems, although I can't imagine why there would be a conflict.
Don
Todd Zimmerman wrote:
> I've got a new install on a Windows box and for some reason VIC is
> crashing on start.
> It crashes when starting even from the command line (vic.exe
> 192.168.1.1/12345 for example...)
> While I assume this may be related to the capture device (I have an
> NCast DCC 3.1 HD capture card), I can't confirm that. I've uninstalled
> the drivers for this device and have physically removed the capture
> card; however the crashes continue.
> Anyone got any advice on how to proceed with debugging? Anything else
> I should betrying (display settings/ network settings). Unfortunately,
> there is no real hint as to the cause of the crash.
> Todd
