[AG-TECH] Windows Vic Crashing
Todd Zimmerman
todd.zimmerman at ubc.ca
Fri Feb 6 11:01:20 CST 2009
On Thu, 2009-02-05 at 19:33 +0000, Piers O'Hanlon wrote:
> Hi Todd,
> Is that a windows XP box? Do you have the latest drivers for the Ncast
> capture card? Presumably you don't still see the dvice in the device
> manager (if so delete it from there and try again). What colour depth
> is your display set to - should be ok on 16 or 24, 32 bits. Are there
> any other capture devices loaded (USB etc?) Do you get any message
> when it crashes?
Windows XP with latest Ncast drivers.
Device has been physically removed and doesn't show up in the device
list.
Colour depth is 32 bit.
No other capture devices loaded.
No message when crash except attached error msg. There is a stack trace
available if you click on the 'more info' link on the error dialog;
however, unfortunately, there is no way to cut/paste/save the stack
trace text from the dialog box (can't even select the text)....
Any other suggestions??
Thanks for all your help.
Todd
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090206/df80bcc5/attachment.png>
