[AG-TECH] Windows Vic Crashing
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Thu Feb 5 13:33:54 CST 2009
Hi Todd,
Is that a windows XP box? Do you have the latest drivers for the Ncast
capture card? Presumably you don't still see the dvice in the device
manager (if so delete it from there and try again). What colour depth
is your display set to - should be ok on 16 or 24, 32 bits. Are there
any other capture devices loaded (USB etc?) Do you get any message
when it crashes?
Piers
2009/2/5 Todd Zimmerman <todd.zimmerman at ubc.ca>:
> I've got a new install on a Windows box and for some reason VIC is
> crashing on start.
> It crashes when starting even from the command line (vic.exe
> 192.168.1.1/12345 for example...)
> While I assume this may be related to the capture device (I have an
> NCast DCC 3.1 HD capture card), I can't confirm that. I've uninstalled
> the drivers for this device and have physically removed the capture
> card; however the crashes continue.
> Anyone got any advice on how to proceed with debugging? Anything else
> I should betrying (display settings/ network settings). Unfortunately,
> there is no real hint as to the cause of the crash.
> Todd
