[AG-TECH] Receiving audio from other RTP apps in RAT?
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Tue Dec 15 13:50:14 CST 2009
Hi Andrew,
Glad to hear you've got things going with gstreamer.
You may be able to achieve what you want by adding the following line
to your .RTPdefaults file:
*rtpPromiscuousMode: 1
We've used RAT to send and receive PCM audio to various devices (VoIP
phones and others).
Piers
2009/12/15 Andrew Ford <andrew.ford at rit.edu>:
> Hi,
> Does anyone know if it's possible to receive audio sent from other
> RTP-compliant applications in RAT? I've been experimenting with transcoding
> audio with gstreamer and sending it back out via multicast RTP, which can be
> received by other gstreamer instances as well as VLC, but RAT acts a little
> strange. The sender shows up in the participant list, and it seems like the
> "talk" is on, but the highlighting blinks intermittently and it shows 0.0
> b/s on the listen meter. Specifically I'm trying to send regular 16-bit,
> 44.1khz PCM audio (sent as RTP payload type 10). Has anyone gotten anything
> like this to work?
> Thanks,
> --Andrew
