[AG-TECH] Venue Server help
Thomas Uram turam at mcs.anl.gov
Thu Aug 6 13:22:55 CDT 2009
The Venue url shows up as:
https://usd-venue.usd.local:8000/Venues/c0ec25bc12c81692c1b57540b79b46e1
I'm sure that hostname is not what you expected. You can likely
configure it better in Windows. Alternatively, you can set the
AG_HOSTNAME environment variable to the right name, or to the IP
address, before running the VenueServer.
Tom
On Aug 6, 2009, at 1:04 PM, Vine, Derek A wrote:
> Here is the log file.  Let me know if there is anything else that is
> needed.
> --Derek
> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov
> ] On Behalf Of Thomas Uram
> Sent: Thursday, August 06, 2009 11:03 AM
> To: Vine, Derek A
> Cc: AG-Tech
> Subject: Re: [AG-TECH] Venue Server help
> On Aug 6, 2009, at 10:33 AM, Vine, Derek A wrote:
> Greetings all.
> We have had a venue server running for a little over a year now and
> I was never able to add any other exits besides the default lobby.
> Whenever I add a new exit and try to access it from our node I get
> the following error: Error entering venue, getaddinfo failed.  Is
> there some sort of security setting that I am missing?
> Can you send the relevant info from the VenueClient.log file? I
> suspect a problem with determining the hostname, which would result
> in an unreachable Venue address.
> The venue server is running on Windows server 2003 and is based off
> of the 3.2 beta 1 all-in-one installer.
> Also, what do I edit to change the location where venue FTP files
> are saved (ie. The data, services and application sessions).  The
> default is in Application Data of the user and I need to move it to
> a different drive.
> The location of downloaded files can not be configured by the user,
> at this time. You should file an enhancement request to that end. It
> would be simple to add.
> Tom
> Thank you in advance.
> Derek Vine
> Communication Network Specialist
> DDN Site Coordinator
> The University of South Dakota
> Office - 605-677-5042
> Cell - 605-677-8215
> dvine at usd.edu
> <VenueClient.log>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090806/12af3db8/attachment.htm>
More information about the ag-tech mailing list
