[AG-TECH] System freezes sending video on Linux w/ IVC-200 capture card
Christoph Willing
c.willing at uq.edu.au
Wed Apr 22 00:13:27 CDT 2009
On 22/04/2009, at 5:42 AM, Andrew Ford wrote:
> 2009/4/20 Christoph Willing <c.willing at uq.edu.au>
> On 21/04/2009, at 3:47 AM, Andrew Ford wrote:
> Hi Chris,
> After some testing we've seen this happen with multiple IVCs and
> multiple machines - at any rate, we don't have any more spare linux
> boxes to test with. I have a feeling it might be related to Ubuntu's
> CPU frequency scaling though, as I've never seen it freeze when I
> manually set it to use the maximum clock speed. What are the clock
> settings on your machine?
>> Andrew,
>> Did you roll your own kernel? When I tried to add the cpu frequency
>> scaler applet, it reports that I don't have it set in the kernel -
>> since I try to keep our build machines as standard as possible
>> (i.e. only latest supplied kernels) and if frequency scaling is
>> working for you, I'm guessing you have a non-standard kernel. In
>> that case I suggest you revert to a standard kernel to test whether
>> the freeze effect goes away. Either the frequency scaling itself
>> or the change of some other kernel option may be causing the freeze
>> effect; reverting to a standard kernel could rule those changes out
>> as the cause.
> Nope, standard kernel - one machine is a clean install of x86
> Intrepid, the other is also x86 Intrepid that's been upgraded from
> Gutsy. What kind of CPUs do you have in your machines? I'm guessing
> Ubuntu automatically detects on install - for example, it's also
> automatically enabled on my laptop, which has a Core 2 Duo. It looks
> like it functions through a variety of kernel modules depending on
> type of processor - "powernow-k8" for Opterons, for example. I'm
> going to try disabling that module to see if that does what I want.
Andrew,
It looks like ability to control the cpu speed via the applet is
determined by a BIOS setting. The intrepid machine here (with Core 2
Quad) has a Dell BIOS. In the Performance section of the BIOS, the
SpeedStep setting was set to Off - in that mode I was unable to set
the cpu speed with the frequency scaler applet. When I turned it On, I
was able to make the adjustments you mentioned. Setting it back to Off
returns it to its 100% usage mode.
On another (AMD) machine with PhoenixBIOS, that setting is in the
Hammer section of the Advanced settings. Enabling the AMD PowerNOW!
entry allows adjustment with the scaler applet; disabling that setting
returns it to 100% mode.
chris
>> In my case, without frequency scaling enabled in the kernel, the
>> scaler applet works in read only mode. From that, I could see that
>> the clock setting is set to 100%.
>> BTW it looks from the applet like the frequency scaling could be
>> set to different values on different cores of a multicore machine -
>> that may also contribute to the freezing.
> No - if you set a speed for a core the displayed speed for the other
> cores on the same processor will change correspondingly.
> --Andrew
> chris
>>> 2009/3/29 Christoph Willing <c.willing at uq.edu.au>
>>>> On 26/03/2009, at 4:58 PM, Christoph Willing wrote:
>>>>> On 26/03/2009, at 3:34 AM, Andrew Ford wrote:
>>>>> Hi,
>>>>> For a while now we've been seeing hard freezes (ie, trying to
>>>>> kill the X server does nothing) on one of our Linux machines
>>>>> when it tries to send video via an IVC-200 cap card. It tends to
>>>>> occur more frequently when the load is heavier - attempting to
>>>>> send 2 or more 720x480 mpeg4 or h.264 streams causes it to
>>>>> freeze within 5-10 minutes, 4 h.261 videos make it freeze in
>>>>> about half an hour, and 2 261 videos makes it last about 2 days.
>>>>> dmesg and /var/log/messages don't give any clues. Other types of
>>>>> load don't seem to cause freezes, and I ran memtest86 overnight
>>>>> with no errors. Originally the machine was Ubuntu 8.04 64-bit,
>>>>> then 8.10 64-bit, then 8.10 32-bit, and the problem was seen in
>>>>> all 3. In all cases it was running the UQ-provided AG 3.2beta
>>>>> with the stock VideoProducer services. I know there was a bttv
>>>>> driver deadlock issue in kernels pre-2.6.24, but this is running
>>>>> kernel 2.6.27 so that shouldn't be the problem.
>>>>> Also when sending video on that machine occasionally the stream
>>>>> would start to flicker, flashing an old frame alternating with
>>>>> the current output of the camera. Has anyone seen either of
>>>>> these issues before?
>>>> Andrew,
>>>> I just installed a 32bit Ubuntu 8.10 on the UQVislab node's video
>>>> capture machine. I've been running 2x mpeg4 streams and an h261
>>>> stream for over two hours. I just powered the machine down to
>>>> confirm it is actually an IVC-200G card (it is). After the
>>>> restart, I've now configured it to run with 3x mpeg4 streams.
>>>> These are full PAL streams 704x576. Its been running for nearly
>>>> 10 minutes now - will leave it running overnight (in the APAG
>>>> lobby, if you want to check on them) and report back. Based on
>>>> the previous successful 2 hour test, I think this 3 large streams
>>>> test will be OK too.
>>> Andrew,
>>> We've now had this setup (32bit Ubuntu 8.10 with IVC-200G
>>> streaming 3x mpeg4 streams @ 704x576) running continuously for
>>> over three days now without any discernible problem. That result
>>> suggests a hardware issue with your capture card (or even the
>>> machine itself).
>>> chris
>> You could try reseating the card - maybe some dust or contact
>> oxidation is creating some bad effect? Do you have any similar
>> capture cards lying around you could temporarily replace the IVC
>> with? That may indicate whether you have a card fault or machine/OS
>> fault.
>> chris
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
