[AG-TECH] Fwd: BUG 1695 really solved?
Todd Zimmerman
todd.zimmerman at ubc.ca
Fri Oct 24 12:33:41 CDT 2008
On Thu, 2008-10-23 at 09:07 -0700, Natalia Costas Lago wrote:
> I have read that Bug 1695 ("Cannot connect to Venue Server with Venue
> Management Tool") was solved in release 3.1. That's the one I have
> installed on our Venue Server, however I have that same problem.
I have also not been able to connect via the VenueManagement tool;
however I had assumed it was because of certificate issues on my end.
As a workaround, for any of the tweaks to my config I've been hand
editing my config files.
I just tested importing the server cert locally and using that as my
default when attempting to connect, but still get a 'failure to connect'
error.
I am not connecting to localhost, and have tried to connect from a
remote machine and the local machine (running on the same account as the
VS) but still no dice. Connection attempts are from both Fedora7 and
Fedora9.
Looking at the log (attached) it ends in a SSLError: certificate verify
failed.
Any other suggestions?
Todd
Collaboration & Visualization Specialist
UBC Okanagan - http://web.ubc.ca/okanagan
WestGrid - www.westgrid.ca
Ph. 250-807-9979
Todd Zimmerman - todd.zimmerman at ubc.ca
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081024/1efc5074/attachment.bin>
