[AG-TECH] Fwd: BUG 1695 really solved?
Jeremy Mann
jeremymann at gmail.com
Fri Oct 24 14:59:04 CDT 2008
On Fri, Oct 24, 2008 at 12:33 PM, Todd Zimmerman <todd.zimmerman at ubc.ca> wrote:
> On Thu, 2008-10-23 at 09:07 -0700, Natalia Costas Lago wrote:
>> I have read that Bug 1695 ("Cannot connect to Venue Server with Venue
>> Management Tool") was solved in release 3.1. That's the one I have
>> installed on our Venue Server, however I have that same problem.
> I have also not been able to connect via the VenueManagement tool;
> however I had assumed it was because of certificate issues on my end.
> As a workaround, for any of the tweaks to my config I've been hand
> editing my config files.
> I just tested importing the server cert locally and using that as my
> default when attempting to connect, but still get a 'failure to connect'
> error.
> I am not connecting to localhost, and have tried to connect from a
> remote machine and the local machine (running on the same account as the
> VS) but still no dice. Connection attempts are from both Fedora7 and
> Fedora9.
Todd, I had this same problem a few weeks ago. When I was connecting
to "localhost" it failed, but if I used the FQDN it worked fine.
Jeremy Mann
jeremy at biochem.uthscsa.edu
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
