[AG-TECH] BUG 1695 really solved?
Natalia Costas Lago
natalia at cesga.es
Fri Oct 24 08:10:52 CDT 2008
Hi Douglas,
It seems I am using that one :((
[root at agserver ~]# rpm -qa | grep python-ZSI
python-ZSI-2.0-2.20070622svn.fc4
Con fecha viernes, 24 de octubre de 2008, 9:40:45, escribió:
> Hi Natalia,
> Since the issue you are having seems to be ZSI based, try:
> yum update python-ZSI
> and make sure you are using python-ZSI-2.0-*.20070622svn.fc4
>> I have read that Bug 1695 ("Cannot connect to Venue Server with Venue
>> Management Tool") was solved in release 3.1. That's the one I have
>> installed on our Venue Server, however I have that same problem.
>> [root at agserver cron.hourly]# rpm -qa | grep -i accessgrid-3
>> AccessGrid-3.1-1.fc4
>> I reinstalled software in January 2008 and I rather prefer not to have
>> to migrate to a beta release that might solve the problem.
>> Does anyone know if that bug was really solved?
> I'm not able to reproduce it with AccessGrid-3.1 on CentOS 5 (which is
> the closet thing I have to FC4 running at the moment). Although I found
> FC4 to more buggier in general than other Fedora versions.
>> I tried connecting to https://localhost:9000 and using the FQDN or the
>> IP address of the server and I get the same result.
> From memory, localhost won't work as the VenueServer doesn't listen on
> that interface for SOAP requests, but hostname or FQDN will.
> Also make sure the FQDN in /etc/hosts is correct (sometimes on Fedora
> systems it is set to 127.0.0.1).
> Doug
Natalia Costas Lago
Técnico de Comunicaciones - Dpto. de Comunicaciones
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n (Campus Sur)
15705 Santiago de Compostela - SPAIN
E-mail: natalia at cesga.es
Tel: +34 981 56 98 10 (ext. 237)
Fax: +34 981 59 46 16
Web: http://www.cesga.es/
