[AG-TECH] Issues with a new AG 3.1 installation.
Miguel Sáez
msaez at cesga.es
Tue May 27 05:15:13 CDT 2008
Hello Ben,
I get exactly the same problems when i try to add an standar
VideoProducerService.
Ben Green escribió:
> Can you confirm whether or not you can add the standard VideoProducerService, in other words, not the H264 one?
> Cheers, Ben.
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Miguel Sáez
> Sent: 26 May 2008 09:55
> To: AG-TECH list
> Subject: [AG-TECH] Issues with a new AG 3.1 installation.
> Hello!,
> I got my Windows XP installed again and i got a lot more info, more or less i know where is the problem but just don't know how to fix it.
> If you check the screenshot 'Devices_installed.jpg' everything is installed correctly.
> 'VideoProducerH264_error.jpg' shows my 'AG Node Manager' and the error i get when i try to add a VideoProducerH264, 193.144.44.84 is my "display"
> computer and 193.144.44.85 is the 'AG Video computer' with the 4 capturers running the Service Manager.
> I also attach the .logs from the 'AG Video computer', if you check the log 'ServiceManager.log' you can see the next error in there:
> 05/26/08 10:25:30 172 ServiceManager agservicemanager.py:424 INFO
> Service failed to register: c1902c55022c36d54a026c396c886e9b
> 05/26/08 10:25:30 172 Hosting servicecontainer.py:17 ERROR
> Processing Failure
> exceptions:Exception
> Service failed to become reachable
> And it happens all the time i try to add a VideoProducerServiceH264 , that might be why i get the error in the screenshot 'VideoProducerH264_error.jpg' but just don't know how to fix it.
> If you check the "VideoProducerServiceH264.log' everything is fine, it also gets all my devices without any problem:
> 05/26/08 10:25:30 248 Toolkit config.py:624 DEBUG wdmscan filelines
> = ["Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n"]
> 05/26/08 10:25:30 248 Toolkit config.py:657 INFO GetResources:
> {'Microsoft WDM Image Capture (Win32)': ['external-in'], "Conexant's BtPCI Capture": ['S-Video', 'Composite']}
> Also i want to add that i don't use any firewall at all on any computer, i'm not behind a NAT and my network isn't behind a firewall either.
> Hope all this info helps a bit more so i can find a solution.
> Thanks a lot for the help!
> Sincerely,
> Miguel Ángel Sáez Llorente
> Técnico de Comunicacións
> Centro de Supercomputación de Galicia (CESGA) Avenida de Vigo, s/n (Campus Sur)
> 15705 Santiago de Compostela - ESPAÑA
> E-mail: msaez at cesga.es
> Tel: +34 981 56 98 10 (ext. 246)
> Fax: +34 981 59 46 16
> Web: http://www.cesga.es/
