[AG-TECH] Issues with a new AG 3.1 installation.
Ben Green
ben.green at manchester.ac.uk
Tue May 27 05:13:06 CDT 2008
Can you confirm whether or not you can add the standard VideoProducerService, in other words, not the H264 one?
Cheers, Ben.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Miguel Sáez
Sent: 26 May 2008 09:55
To: AG-TECH list
Subject: [AG-TECH] Issues with a new AG 3.1 installation.
Hello!,
I got my Windows XP installed again and i got a lot more info, more or less i know where is the problem but just don't know how to fix it.
If you check the screenshot 'Devices_installed.jpg' everything is installed correctly.
'VideoProducerH264_error.jpg' shows my 'AG Node Manager' and the error i get when i try to add a VideoProducerH264, 193.144.44.84 is my "display"
computer and 193.144.44.85 is the 'AG Video computer' with the 4 capturers running the Service Manager.
I also attach the .logs from the 'AG Video computer', if you check the log 'ServiceManager.log' you can see the next error in there:
05/26/08 10:25:30 172 ServiceManager agservicemanager.py:424 INFO
Service failed to register: c1902c55022c36d54a026c396c886e9b
05/26/08 10:25:30 172 Hosting servicecontainer.py:17 ERROR
Processing Failure
exceptions:Exception
Service failed to become reachable
And it happens all the time i try to add a VideoProducerServiceH264 , that might be why i get the error in the screenshot 'VideoProducerH264_error.jpg' but just don't know how to fix it.
If you check the "VideoProducerServiceH264.log' everything is fine, it also gets all my devices without any problem:
05/26/08 10:25:30 248 Toolkit config.py:624 DEBUG wdmscan filelines
= ["Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI Capture,S-Video,Composite\n"]
05/26/08 10:25:30 248 Toolkit config.py:657 INFO GetResources:
{'Microsoft WDM Image Capture (Win32)': ['external-in'], "Conexant's BtPCI Capture": ['S-Video', 'Composite']}
Also i want to add that i don't use any firewall at all on any computer, i'm not behind a NAT and my network isn't behind a firewall either.
Hope all this info helps a bit more so i can find a solution.
Thanks a lot for the help!
Sincerely,
Miguel Ángel Sáez Llorente
Técnico de Comunicacións
Centro de Supercomputación de Galicia (CESGA) Avenida de Vigo, s/n (Campus Sur)
15705 Santiago de Compostela - ESPAÑA
E-mail: msaez at cesga.es
Tel: +34 981 56 98 10 (ext. 246)
Fax: +34 981 59 46 16
Web: http://www.cesga.es/
