[AG-TECH] Bridge error
Jonathan Narvaez
jonaabd07 at gmail.com
Tue May 27 12:37:33 CDT 2008
I have problems with my network, i can't transmitte video on diferents
subnets
example:
server:192.168.101.148
client 1: 192.168.147.8
client 2: 192.168.113.7
This client not recive and transmitte video and audio, maybe problem this
router or add rule router for multicast transmitte.
Thanks
I sorry for my bad English
On Mon, May 26, 2008 at 10:20 PM, Jonathan Narvaez <jonaabd07 at gmail.com>
wrote:
> run it is a regular user not workly, run is only root the applications:
> Server, Managment and Bridge.
> Thanks
> On Mon, May 26, 2008 at 10:12 PM, Thomas D. Uram <turam at mcs.anl.gov>
> wrote:
>> That command should work, yes. I would not recommend running it as root,
>> though: It's not necessary that it run as root, and it's actually better to
>> run it as a regular user if you can (as with most software).
>> Tom
>> On 5/26/08 9:58 PM, Jonathan Narvaez wrote:
>> this command correct is:
>> jnarvaez at jnarvaez-desktop:~$ sudo Bridge3.py --name=UniminutoBridge
>> --location=Colombia --listenPort=9000 --qbexec=/usr/bin/QuickBridge
>> --portRange=41000 50000
>> for this to work?
>> Sorry for my English
>> On Fri, May 23, 2008 at 11:07 PM, Thomas D. Uram <turam at mcs.anl.gov>
>> wrote:
>>> The value you're specifying for the registryUrl argument is incorrect.
>>> If you omit this argument, the bridge will register with the default
>>> bridge registry and be available to everyone. I'd recommend that you take
>>> this approach first.
>>> If this is not what you want, you'll need to run your own registry, and
>>> create a bootstrap file reachable at some URL, using that URL for the
>>> registryUrl argument. The bootstrap file should include simply the
>>> hostname:port of your registry. As an example, you can look at the default
>>> bootstrap file at
>>> http://www.accessgrid.org/registry/peers.txt
>>> Tom
>>> On 5/23/08 10:12 PM, Jonathan Narvaez wrote:
>>> I need your help
>>> I get to start this error.
>>> --portRange=41000 50000 --registryUrl=
>>> https://prueba.uniminuto.edu:8000/Venues/default
>>> [sudo] password for jnarvaez:
>>> Traceback (most recent call last):
>>> File "/usr/bin/Bridge3.py", line 187, in <module>
>>> main()
>>> File "/usr/bin/Bridge3.py", line 182, in main
>>> bridgeServer = QuickBridgeServer(name=options.name,
>>> location=options.location, listenPort=options.listenPort,
>>> qbexec=options.qbexec, portRange=options.portRange,
>>> registryUrl=options.registryUrl)
>>> File "/usr/bin/Bridge3.py", line 47, in __init__
>>> self._RegisterWithRegistry()
>>> File "/usr/bin/Bridge3.py", line 84, in _RegisterWithRegistry
>>> self.validSecs =
>>> self.registryClient.RegisterBridge(self.bridgeDescription)
>>> File
>>> "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Registry/RegistryClient.py",
>>> line 74, in RegisterBridge
>>> self._connectToRegistry()
>>> File
>>> line 45, in _connectToRegistry
>>> self.registryPeers = self._readPeerList(url=self.url)
>>> File
>>> line 162, in _readPeerList
>>> f = urllib.urlopen(url)
>>> File "/usr/lib/python2.5/urllib.py", line 82, in urlopen
>>> return opener.open(url)
>>> File "/usr/lib/python2.5/urllib.py", line 190, in open
>>> return getattr(self, name)(url)
>>> File "/var/lib/python-support/python2.5/M2Crypto/m2urllib.py", line 58,
>>> in open_https
>>> h.endheaders()
>>> File "/usr/lib/python2.5/httplib.py", line 856, in endheaders
>>> self._send_output()
>>> File "/usr/lib/python2.5/httplib.py", line 728, in _send_output
>>> self.send(msg)
>>> File "/usr/lib/python2.5/httplib.py", line 695, in send
>>> self.connect()
>>> File "/var/lib/python-support/python2.5/M2Crypto/httpslib.py", line 47,
>>> in connect
>>> self.sock.connect((self.host, self.port))
>>> File "/var/lib/python-support/python2.5/M2Crypto/SSL/Connection.py", line
>>> 152, in connect
>>> self.socket.connect(addr)
>>> File "<string>", line 1, in connect
>>> IOError: [Errno socket error] (111, 'Connection refused')
>>> Thanks
>>> Jonathan Narvaez
>>> - En la Caja decía 'instalar Windows 95 o Superior' Asi que instale
>>> Linux"
>>> - Si reproduces un CD de Microsoft al revés puedes escuchar un mensaje
>>> satánico...
>>> - Eso no es lo peor... Al derecho te instala windows...
>> Jonathan Narvaez
>> - En la Caja decía 'instalar Windows 95 o Superior' Asi que instale Linux"
>> satánico...
> Jonathan Narvaez
> satánico...
Jonathan Narvaez
satánico...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080527/e5a128f2/attachment.htm>
