[AG-TECH] Issues with a new AG 3.1 installation.
Miguel Sáez
msaez at cesga.es
Mon May 26 03:54:48 CDT 2008
Hello!,
I got my Windows XP installed again and i got a lot more info, more or
less i know where is the problem but just don't know how to fix it.
If you check the screenshot 'Devices_installed.jpg' everything is
installed correctly.
'VideoProducerH264_error.jpg' shows my 'AG Node Manager' and the error i
get when i try to add a VideoProducerH264, 193.144.44.84 is my "display"
computer and 193.144.44.85 is the 'AG Video computer' with the 4
capturers running the Service Manager.
I also attach the .logs from the 'AG Video computer', if you check the
log 'ServiceManager.log' you can see the next error in there:
05/26/08 10:25:30 172 ServiceManager agservicemanager.py:424 INFO
Service failed to register: c1902c55022c36d54a026c396c886e9b
05/26/08 10:25:30 172 Hosting servicecontainer.py:17 ERROR
Processing Failure
exceptions:Exception
Service failed to become reachable
And it happens all the time i try to add a VideoProducerServiceH264 ,
that might be why i get the error in the screenshot
'VideoProducerH264_error.jpg' but just don't know how to fix it.
If you check the "VideoProducerServiceH264.log' everything is fine, it
also gets all my devices without any problem:
05/26/08 10:25:30 248 Toolkit config.py:624 DEBUG wdmscan filelines
= ["Conexant's BtPCI Capture,S-Video,Composite\n", "Conexant's BtPCI
Capture,S-Video,Composite\n"]
05/26/08 10:25:30 248 Toolkit config.py:657 INFO GetResources:
{'Microsoft WDM Image Capture (Win32)': ['external-in'], "Conexant's
BtPCI Capture": ['S-Video', 'Composite']}
Also i want to add that i don't use any firewall at all on any computer,
i'm not behind a NAT and my network isn't behind a firewall either.
Hope all this info helps a bit more so i can find a solution.
Thanks a lot for the help!
Sincerely,
Miguel Ángel Sáez Llorente
Técnico de Comunicacións
Centro de Supercomputación de Galicia (CESGA)
Avenida de Vigo, s/n (Campus Sur)
15705 Santiago de Compostela - ESPAÑA
E-mail: msaez at cesga.es
Tel: +34 981 56 98 10 (ext. 246)
Fax: +34 981 59 46 16
Web: http://www.cesga.es/
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080526/168850bd/attachment.jpg>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080526/168850bd/attachment.diff>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080526/168850bd/attachment-0001.jpg>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080526/168850bd/attachment-0001.diff>
