[AG-TECH] Recording own audio/video locally with AGVCR
Derek Piper
dcpiper at indiana.edu
Mon Mar 17 13:08:37 CDT 2008
Hi Ben,
For recording yourself, you just need to get VIC and RAT to transmit,
so you'll need to go into the options in VIC and select 'Configure on
Transmit' and then check the 'Transmit' box. After you're transmitting,
boost your quality and bitrate sliders to something pleasing and you
should be off and running.
If you have problems getting AGVCR to receive packets via localhost, as
has happened some times, then you can always use a multicast address
(pick something like 239.1.x.x (where .x is greater than 1) and set your
TTL to 1 so you don't end up broadcasting across the internet. Pick a
suitable port number too. If you connect VIC and RAT to those addresses
and you see other people on there then choose another address. Or you
could hang around and chat to them, maybe they're trying to record
themselves too...
One other way is to either book a venue or use a local venue server and
record yourself that way by joining the venue and letting the AG start
the tools and run AGVCR from that venue.
I know I need to get the AGVCR website running properly again with its
FAQ. I'll try doing that some time :)
Derek
Ben Green wrote:
> Is it possible to use AGVCR as a 'DVR'?
> I want to record the output from multiple cameras/mics connected to my laptop (at that time, not connected to a virtual venue), and then at a later date play this back to a virtual venue. I obviously know how to do the playback part.
> Looking at AGVCR, it appears that it can only capture RTP coming from a virtual venue. But what I want to do is essentially the reverse of 'Local Playback' - but I don't know how to record from localhost.
> Cheers, Ben.
> Ben Green
> Access Grid Support Centre
> Research Computing Services
> University of Manchester
> Room G49-H, Kilburn Building
> Oxford Road, Manchester, M13 9PL
> tel: +44 (0)161 306 6621
> fax: +44 (0)161 275 0637
> email - ben.green at manchester.ac.uk
> web - www.agsc.ja.net
Derek Piper - dcpiper at indiana.edu - (812) 855 5560
System Administrator / Informatics Specialist
IU Molecular Structure Center, A421C, Chemistry
Indiana University, Bloomington, Indiana
