[AG-TECH] Using a Proxy Server with AG3
Horwich, A (Adam)
A.Horwich at rl.ac.uk
Thu Jan 17 04:38:11 CST 2008
Could try making the proxy entry something like:
<domain>\\<username>:<pass>@<proxy>
Or maybe a single backslash.
We don't use authentication on our proxy so I can't test it out
unfortunately.
Adam.
From: Ben Green [mailto:ben.green at manchester.ac.uk]
Sent: 17 January 2008 09:39
To: ag-tech at mcs.anl.gov
Cc: Horwich, A (Adam)
Subject: RE: [AG-TECH] Using a Proxy Server with AG3
I'm helping this same user get his AG3 client working via a proxy
server.
I've got him to amend the preferences files, and the client can now
connect to the proxy, but a second problem has arisen which may not be
fixable. His comment is below:
For staff to access the internet from a local laptop they have to put in
the domain/username and then there password. And in most programs where
you can put proxy details in there is generally a section for
authentication. As there isn't a section I get a feeling that this just
isn't going to work over our network... Is there a fix, patch or a
suggestion to this issue?
Does anyone have any experience of this type of proxy?
Regards, Ben.
From: Horwich, A (Adam) [mailto:A.Horwich at rl.ac.uk]
Sent: 16 January 2008 12:59
To: ben.green at manchester.ac.uk
Cc: ag-tech at mcs.anl.gov
Hi Ben,
Yep it's been doing it since AG3.1 beta 1 and I have no idea why. The
only thing I can do is, if I need to make any preferences changes, to
then edit the preferences file and change the proxy port number
manually. I submitted a bug on the issue but haven't had any response
yet.
Adam.
P.s Sorry about the previous message. Hit the wrong button!!
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Ben Green
Sent: 16 January 2008 12:12
Subject: [AG-TECH] Using a Proxy Server with AG3
When a proxy server is configured within Tools / Preferences / Network,
and a port number is specified, after saving the configuration, this
port number is set to zero.
Has anyone else seen this, or does anyone know why this happens?
Regards, Ben.
Ben Green
Access Grid Support Centre
University of Manchester
Room G49-H
Kilburn Building
Oxford Road
Manchester
M13 9PL
tel - 0161 306 6621
email - ben.green at manchester.ac.uk
web - www.agsc.ja.net
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080117/abfb831d/attachment.htm>
