[AG-TECH] Rat and MBUS problems
Jeremy Mann
jeremymann at gmail.com
Wed May 23 08:27:00 CDT 2007
On 5/22/07, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
> I assume you mean Linux AG 2.4 client rather than Linux kernel 2.4
> clients.
Yes, I meant 2.4 client.
> You didn't have a USB webcam plugged in during the power up? It may have
> become your primary audio device. Try running alsamixer on the
> command-line to see what it thinks is the primary audio device.
I have the cameras microphone disabled. I've tried using the onboard
sound (which used to work) and a USB audio device as well. Both have
the same problem.
> Try switching from ALSA to OSS in rat and see if that helps.
I could if RAT would load, it doesn't even come up.
> If it is only happening to AG 2.4 rat and not AG 3.0.2 rat, copy the new
> rat binary, e.g:
> cp -p .AccessGrid3/local_services/AudioService/rat* \
> .AccessGrid/local_services/AudioService/
Its affecting both versions.
