[AG-TECH] building AG3 on ubuntu edgy
Brad Langhorst
brad at langhorst.com
Thu Mar 8 16:21:02 CST 2007
On Thu, 2007-03-08 at 14:12 -0600, Eric Olson wrote:
> The error you're getting:
> > ImportError: No module named AccessGrid.Toolkit
> means python can't find the 3.0 "AccessGrid" or "AccessGrid.Toolkit"
> module(s). It is likely that your PYTHONPATH is not set correctly. The
> env-init.sh is supposed to set it. You can do "echo ${PYTHONPATH}" to
> see what its value is and then correct it. If you need more help with
> that part, let me know.
> Yes, a debian/ubuntu package is definitely needed. It's been worked on
> but not finished.
> If you have any more problems, please send mail.
> Eric
Well, I think I'm making progress with the help you've given me.
I've updated zsi to the head and figured out the problem with the path.
Now I get a new error : No module named OpenSSL_AG.crypto
I don't find anything similarly named in AccessGrid or in ag-media.
I do have the openssl 0.9.8 and it's -dev package installed , though
none of the configure scripts seemed to look for ssl headers.
I thought maybe it was related to m2crypto... i had 0.16, so i upgraded
to the 0.17 mentioned at
http://www-new.mcs.anl.gov/fl/research/accessgrid/software/cvs.html
but that did not seem to help.
I couldn't figure out how to do the equivalent of make clean in
AccessGrid so I just re-checked everything out and rebuilt, no change.
What am I missing?
Brad
full details below:
bwlang at upup:/usr/src$ python AccessGrid/bin/VenueClient.py
--personalNode
Traceback (most recent call last):
File "AccessGrid/bin/VenueClient.py", line 30, in ?
from AccessGrid.VenueClientUI import VenueClientUI
File "/usr/src/AccessGrid/AccessGrid/VenueClientUI.py", line 47, in ?
from AccessGrid.Security.wxgui.AuthorizationUI import
AuthorizationUIDialog
File
"/usr/src/AccessGrid/AccessGrid/Security/wxgui/AuthorizationUI.py", line
30, in ?
from AccessGrid.interfaces.AuthorizationManager_client import
AuthorizationManagerIW
File
"/usr/src/AccessGrid/AccessGrid/interfaces/AuthorizationManager_client.py", line 7, in ?
from AuthorizationManager_messages import *
File
"/usr/src/AccessGrid/AccessGrid/interfaces/AuthorizationManager_messages.py", line 29, in ?
AddSubjectToRoleRequest =
www_accessgrid_org_v3_0_authorizationmanager.AddSubjectToRoleRequest().pyclass
File
"/usr/src/AccessGrid/AccessGrid/interfaces/AG_AuthorizationManager_Types.py", line 692, in __init__
TClist =
[GTD("http://www.accessgrid.org/v3.0","X509Subject",lazy=False)(pname=(ns,"subject"), aname="subject", minOccurs=1, maxOccurs=1, nillable=False, typed=False, encoded=kw.get("encoded")), GTD("http://www.accessgrid.org/v3.0","Role",lazy=False)(pname=(ns,"role"), aname="role", minOccurs=1, maxOccurs=1, nillable=False, typed=False, encoded=kw.get("encoded"))]
File
"/usr/src/AccessGrid/AccessGrid/interfaces/AG_NodeService_Types.py",
line 479, in __init__
import AccessGrid.Security.X509Subject
File "/usr/src/AccessGrid/AccessGrid/Security/X509Subject.py", line
20, in ?
from OpenSSL_AG.crypto import X509NameType
ImportError: No module named OpenSSL_AG.crypto
