[AG-TECH] Starting VIC without a GUI
    Christoph Willing
    willing at vislab.uq.edu.au
    Fri Mar  2 16:11:16 CST 2007
On 03/03/2007, at 5:59 AM, Robert Olson wrote:
> interesting, I wonder how that all gets along with multicast. Seems
> an interesting way to run bridges as well.
No problems with multicast - we had a system running like that (with
Xen) for about a year. The guest OS had its own IP address, separate
from the host OS.
Haven't done enough with KVM to know the potential issues yet.
chris
> On Mar 2, 2007, at 1:53 PM, Christoph Willing wrote:
>> On 02/03/2007, at 10:35 AM, Piers O'Hanlon wrote:
>>> Hi Sam,
>>> On 01/03/07, Sam Gundry <sgundry at vpac.org> wrote: Arh, okay.
>>> Thanks guys, I've had a look through numerous docs but
>>> couldn't find anything. I thought I'd read somewhere that there
>>> was such
>>> a command...
>>> Unfortunately, as mentioned, it isn't currently possible to run
>>> vic without an interface as the tcl GUI is integral to the tool.
>>> One solution, if you for example you have a headless UNIX
>>> machine, would be to point the DISPLAY at a vncserver (a virtual
>>> X11 server) - that way you don't have the GUI showing up anywhere
>>> and vic just runs - though you'd need to set it up to transmit on
>>> startup. You could remotely access the GUI using a vnclient.
>> Along similar lines, you could also run vic in a virtual frame
>> buffer version of X (Xvfb). Using Xen or some other machine
>> virtualisation system, this technique can be used to have a
>> "separate" capture machine along with a display machine both in
>> the same physical box. For an example implementation, see http://
>> www.vislab.uq.edu.au/research/accessgrid/software/xenag/). These
>> days, Linux KVM (kernel virtual machine, not keyboard/video/mouse)
>> is probably a better way to do the machine virtualisation. I
>> believe you need kernel 2.6.20 to do KVM without patches (and
>> supported cpu).
>> chris
>>> Robert Olson wrote:
>>> > That's correct, unlike rat which is split explicitly into audio-
>>> engine,
>>> > controller, and UI components, vic is a monolithic app that has
>>> the GUI
>>> > stuff wrapped up at a fairly fundamental level.
>>> > --bob
>>> > On Mar 1, 2007, at 7:44 AM, Derek Piper wrote:
>>> >>     That should be:
>>> >> vic -t ttl address/port
>>> >> e.g.
>>> >> vic -t 127 233.2.171.246/59966
>>> >>     .. and that just starts VIC with those network settings, it
>>> >> doesn't hide the GUI. As far as I know there are no such
>>> arguments
>>> >> that do that.
>>> >>     Derek
>>> >> Mike Daley wrote:
>>> >>> Hi Sam
>>> >>> the command line is
>>> >>> vic -ttl address port
>>> >>> i.e
>>> >>> vic -127 233.2.171.246/59966
>>> >>> Mike
>>> >>> Sam Gundry wrote:
>>> >>>> Hi,
>>> >>>> Does VIC have a command-line argument to start without it's
>>> GUI?
>>> >>>> Regards,
>>> >>>> Sam
>>> >> --Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>>> >> IRI 323, School of Informatics
>>> >> Indiana University, Bloomington, Indiana
>>> Centre for Computational Prototyping
>>> Victorian Partnership for Advanced Computing
>>> www.vpac.org
>> Christoph Willing                       +61 7 3365 8350
>> QCIF Access Grid Manager
>> University of Queensland
