[AG-TECH] Starting VIC without a GUI
    Robert Olson
    olson at mcs.anl.gov
    Fri Mar  2 13:59:21 CST 2007
interesting, I wonder how that all gets along with multicast. Seems
an interesting way to run bridges as well.
--bob
On Mar 2, 2007, at 1:53 PM, Christoph Willing wrote:
> On 02/03/2007, at 10:35 AM, Piers O'Hanlon wrote:
>> Hi Sam,
>> On 01/03/07, Sam Gundry <sgundry at vpac.org> wrote: Arh, okay.
>> Thanks guys, I've had a look through numerous docs but
>> couldn't find anything. I thought I'd read somewhere that there
>> was such
>> a command...
>> Unfortunately, as mentioned, it isn't currently possible to run
>> vic without an interface as the tcl GUI is integral to the tool.
>> One solution, if you for example you have a headless UNIX machine,
>> would be to point the DISPLAY at a vncserver (a virtual X11
>> server) - that way you don't have the GUI showing up anywhere and
>> vic just runs - though you'd need to set it up to transmit on
>> startup. You could remotely access the GUI using a vnclient.
> Along similar lines, you could also run vic in a virtual frame
> buffer version of X (Xvfb). Using Xen or some other machine
> virtualisation system, this technique can be used to have a
> "separate" capture machine along with a display machine both in the
> same physical box. For an example implementation, see http://
> www.vislab.uq.edu.au/research/accessgrid/software/xenag/). These
> days, Linux KVM (kernel virtual machine, not keyboard/video/mouse)
> is probably a better way to do the machine virtualisation. I
> believe you need kernel 2.6.20 to do KVM without patches (and
> supported cpu).
> chris
>> Robert Olson wrote:
>> > That's correct, unlike rat which is split explicitly into audio-
>> engine,
>> > controller, and UI components, vic is a monolithic app that has
>> the GUI
>> > stuff wrapped up at a fairly fundamental level.
>> > --bob
>> > On Mar 1, 2007, at 7:44 AM, Derek Piper wrote:
>> >>     That should be:
>> >> vic -t ttl address/port
>> >> e.g.
>> >> vic -t 127 233.2.171.246/59966
>> >>     .. and that just starts VIC with those network settings, it
>> >> doesn't hide the GUI. As far as I know there are no such arguments
>> >> that do that.
>> >>     Derek
>> >> Mike Daley wrote:
>> >>> Hi Sam
>> >>> the command line is
>> >>> vic -ttl address port
>> >>> i.e
>> >>> vic -127 233.2.171.246/59966
>> >>> Mike
>> >>> Sam Gundry wrote:
>> >>>> Hi,
>> >>>> Does VIC have a command-line argument to start without it's GUI?
>> >>>> Regards,
>> >>>> Sam
>> >> --Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>> >> IRI 323, School of Informatics
>> >> Indiana University, Bloomington, Indiana
>> Centre for Computational Prototyping
>> Victorian Partnership for Advanced Computing
>> www.vpac.org
> Christoph Willing                       +61 7 3365 8350
> QCIF Access Grid Manager
> University of Queensland
