[AG-TECH] Starting VIC without a GUI
    Christoph Willing
    willing at vislab.uq.edu.au
    Fri Mar  2 13:53:46 CST 2007
On 02/03/2007, at 10:35 AM, Piers O'Hanlon wrote:
> Hi Sam,
> On 01/03/07, Sam Gundry <sgundry at vpac.org> wrote: Arh, okay. Thanks
> guys, I've had a look through numerous docs but
> couldn't find anything. I thought I'd read somewhere that there was
> such
> a command...
> Unfortunately, as mentioned, it isn't currently possible to run vic
> without an interface as the tcl GUI is integral to the tool. One
> solution, if you for example you have a headless UNIX machine,
> would be to point the DISPLAY at a vncserver (a virtual X11 server)
> - that way you don't have the GUI showing up anywhere and vic just
> runs - though you'd need to set it up to transmit on startup. You
> could remotely access the GUI using a vnclient.
Along similar lines, you could also run vic in a virtual frame buffer
version of X (Xvfb). Using Xen or some other machine virtualisation
system, this technique can be used to have a "separate" capture
machine along with a display machine both in the same physical box.
For an example implementation, see http://www.vislab.uq.edu.au/
research/accessgrid/software/xenag/). These days, Linux KVM (kernel
virtual machine, not keyboard/video/mouse) is probably a better way
to do the machine virtualisation. I believe you need kernel 2.6.20 to
do KVM without patches (and supported cpu).
chris
> Robert Olson wrote:
> > That's correct, unlike rat which is split explicitly into audio-
> engine,
> > controller, and UI components, vic is a monolithic app that has
> the GUI
> > stuff wrapped up at a fairly fundamental level.
> > --bob
> > On Mar 1, 2007, at 7:44 AM, Derek Piper wrote:
> >>     That should be:
> >> vic -t ttl address/port
> >> e.g.
> >> vic -t 127 233.2.171.246/59966
> >>     .. and that just starts VIC with those network settings, it
> >> doesn't hide the GUI. As far as I know there are no such arguments
> >> that do that.
> >>     Derek
> >> Mike Daley wrote:
> >>> Hi Sam
> >>> the command line is
> >>> vic -ttl address port
> >>> i.e
> >>> vic -127 233.2.171.246/59966
> >>> Mike
> >>> Sam Gundry wrote:
> >>>> Hi,
> >>>> Does VIC have a command-line argument to start without it's GUI?
> >>>> Regards,
> >>>> Sam
> >> --Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> >> IRI 323, School of Informatics
> >> Indiana University, Bloomington, Indiana
> Centre for Computational Prototyping
> Victorian Partnership for Advanced Computing
> www.vpac.org
Christoph Willing                       +61 7 3365 8350
QCIF Access Grid Manager
University of Queensland
