[AG-TECH] Re: Possible Bug with VenueManager
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Jun  7 13:50:09 CDT 2007
Hi West:
AG2 or AG3?
AG3 does not have any facility for using a certificate with passphrase,
so you should
use a VenueServer service certificate to run a VenueServer.  The 3.1
release will allow
you to assign administrative rights to individuals who hold Identity
Certificates, which
do require a passphrase.
So the behavior you're seeing is appropriate to the current AG3 release.
Tom
On 6/1/07 3:49 PM, west suhanic wrote:
> Hello All:
> There may be a problem with the VenueManager code.
> I am running my own VenueServer. In order to run your own VenueServer
> you need to generate your own x509 certificates. The problem arises
> when I use a x509 certificate for the VenueServer that requires the user
> starting the VenueServer to supply a password. If I use this type of
> certificate
> the VenueServer starts and operates fine. However when I go to
> configure the
> VenueServer using the VenueManager, I cannot connect the VenueManager to
> the VenueServer. When I start the VenueManager it prompts me for the
> password
> for the x509 certificate however it will noyt connect me to the
> VenueServer. If
> I use a x509 certificate that does not prompt for a password the
> VenueManager works
> as expected.
> Hopefully someone else can test this scenario to verify my statements.
> regards,
> West
