[AG-TECH] Possible Bug with VenueManager
    west suhanic
    west.suhanic at gmail.com
    Fri Jun  1 15:49:44 CDT 2007
Hello All:
There may be a problem with the VenueManager code.
I am running my own VenueServer. In order to run your own VenueServer
you need to generate your own x509 certificates. The problem arises
when I use a x509 certificate for the VenueServer that requires the user
starting the VenueServer to supply a password. If I use this type of
certificate
the VenueServer starts and operates fine. However when I go to configure the
VenueServer using the VenueManager, I cannot connect the VenueManager to
the VenueServer. When I start the VenueManager it prompts me for the
password
for the x509 certificate however it will noyt connect me to the VenueServer.
If
I use a x509 certificate that does not prompt for a password the
VenueManager works
as expected.
Hopefully someone else can test this scenario to verify my statements.
regards,
West
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070601/3e04f4a7/attachment.htm>
