[AG-TECH] VenueClient and vic weirdness
Dana Koch
dana at sirca.org.au
Tue Jun 5 22:16:27 CDT 2007
I believe so (are you talking about versioning or something
different?) -- this was the first time I installed AG on this computer.
vic -v reports VIC 2.8ucl-1.1.3-AG. And yes, once I use vic to connect
to one bridge, it seems to work for everything.
I will try and see if firewall changes will improve things.
Dana
Andrew Rowley wrote:
> Hi,
> Are you sure that the vic you are running is the same in both cases?
> Once you have run vic on the command line, does it then work when you
> change venues in the client?
> I think there was a change in later versions of vic that sent out
> packets when it started in order to open your firewall. If you are
> running this later version from the command line, this could be
> opening your firewall and thus allowing the traffic in. In this
> case, check your firewall is allowing incoming traffic on the
> appropriate ports and it should then work within AGTk without needing
> to run it on the command line first.
> Andrew :)
> ============================================ Access Grid Support
> Centre, RSS Group, Manchester Computing, Kilburn Building, University
> of Manchester, Oxford Road, Manchester, M13 9PL, UK Tel:
> +44(0)161-275 0685 Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message----- From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Dana Koch Sent: 05
> June 2007 03:01 To: ag-tech at mcs.anl.gov Subject: [AG-TECH]
> Hi, I've been experiencing some weirdness getting the VenueClient to
> work smoothly on FC5 (Linux). Starting the VenueClient only I get
> "Waiting for video" from vic either on multicast or unicast. However,
> if before I start the VenueClient I open vic from the command line
> with the bridge address and port on unicast, start to transmit (with
> x11, say), I can see all the various video streams. And on restarting
> the VenueClient, everything works as it should!
> I haven't tested rat yet.
> This seems very strange. Is this a bug, or is this some network
> configuration problem?
> Thanks Dana Koch
> SIRCA PO Box H58, Australia Square, Sydney NSW 1215 Level 2, 9
> Castlereagh St, Sydney NSW 2000 Tel: +61 2 9236 9113 Fax: +61 2 9231
> 5988 Web: www.sirca.org.au
