[AG-TECH] Windows XP problem
    Ed Brannin
    edbrannin at gmail.com
    Wed Jul 18 16:20:49 CDT 2007
On 7/18/07, Jeremy Mann <jeremymann at gmail.com> wrote:
> 07/18/07 13:38:28 1408 Toolkit     config.py:419 ERROR Exception
> configuring fir
> ewall for application: C:\Documents and
> Settings\username_was_here\Application Data\Acce
> ssGrid3\local_services\VideoConsumerService\vic.exe^M
> Traceback (most recent call last):^M
>   File
> "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\Conf
> ig.py", line 390, in __AppFirewallConfig^M
>     _winreg.KEY_ALL_ACCESS)^M
> WindowsError: [Errno 5] Access is denied^M
Looks like it's trying to make a firewall exception for something, but your
client doesn't have Windows' permission to modify (that part of) the
registry.  Is he running as a limited user, or an administrator?
The line in question is trying to set this Registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\%s\AuthorizedApplications\List
...where %s is either "StandardDomain" or "LocalDomain" (AG tries to set
both).
So, I'm guessing it's either:
* He's running as a non-administrator, and doesn't have write access to
HKEY_LOCAL_MACHINE
* He's using a registry protector like Spybot Search & destroy, and once
told the program to deny changes from AccessGrid or whatnot.  It's really
easy to click through something like that without really noticing.
He could try upgrading to the 3.1 beta, but that part of the code doesn't
seem to have changed -- at best, maybe it'll give him new warnings that he
can be sure to click "Allow" for.  But first, I'd check if he can run AG as
an administrator.
Since I'm not really sure that's it, I'm going to CC: this to the ag-tech
list.
-Ed Brannin
cell: 585-261-0279
Is this a local firewall issue?
> > > I have one client who is always having this problem and I can't
> > > reproduce it. He has a XP machine with AG 3.0.2 installed. 9 times out
> > > of 10, when he clicks on Go in the Venue Client to connect to our
> > > venue, VIC and RAT fail to appear.
> > Have you checked the logs for anything out of the ordinary?
> > Next time it fails, look in  %HOMEPATH%\Application
> Data\AccessGrid3\Logs --
> > check any files modified in the past 5 minutes for error messages near
> the
> > bottom.
> > (%HOMEPATH% is usually c:\documents and Settings\yourname -- and you'll
> have
> > to make Hidden Files visible before you can click on Application Data.)
> > Hope this helps,--
> > -Ed Brannin
> > cell: 585-261-0279
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070718/df063b6e/attachment.htm>
