[AG-TECH] a few AG3.1 beta problems
Andrew Ford
acf0659 at rit.edu
Thu Jul 12 12:08:38 CDT 2007
Hi Antonio,
We're seeing the second problem (adding a new service when using unicast
causes old ones to restart on a multicast address) here at RIT, running
Windows XP. I just submitted a bug report for it (
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1678).
--Andrew Ford
On 7/12/07, Antonio Bandeira <bandeira at fe.up.pt> wrote:
> Hi,
> I've found a few "problems" with the new AG3.1 beta. Don't know if it is
> just me, but...
> I am currently running FC7, but I think some of this problems can also be
> found in WinXP.
> - Bridge sorting is not persistent. After restart agtk the order is no
> longer the one set under "preferences".
> - Working in unicast mode, adding a new service under "node management"
> will
> cause all previously added services to restart using a multicast address.
> - Autoplace from VIC will not show up for the second time I try to set it.
> The first time I hit 'autoplace' in vic, it works fine. I can set it ok
> and
> when done I hit 'quit'. When I try to set it again, hitting 'autoplace'
> button in vic, it does nothing.
> I also had problems connecting to a 3.0.2 Venue Server with encryption set
> up. Vic was not able to connect. I am not very sure about this, but at
> that
> time, the only way to solve it was removing encryption from the venue
> configuration.
> Best regards,
> António Bandeira
> FEUP :: SICC ~ uTICM
> +351 225 574 199 (ext.3535)
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070712/8c21098b/attachment.htm>
