[AG-TECH] Re: Compiling VIC in Visual Studio 8 (2005)
    Joseph Stone
    stone004 at umn.edu
    Tue Jan 30 10:53:10 CST 2007
I just did a test.  If I bring up "Manage My Node" and Disable the
VideoConsumerService, wait, and then Enable it again, it gets the
streams.  Was this just chance or will this work every time?
Joe
On Jan 30, 2007, at 2:49 AM, Andrew A Rowley wrote:
> Hi,
> If you are using unicast, this is the way in which it works.  Only
> one of the vic instances can bind to the unicast port, which means
> that sometimes you will see video in the VideoConsumerService
> window, and sometimes in the VideoProducerService window.  It is
> fairly random as to which gets the video.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070130/734a74ea/attachment.htm>
