[AG-TECH] Re: Compiling VIC in Visual Studio 8 (2005)
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Jan 30 11:07:31 CST 2007
That will work every time.  It is actually not random behavior.  The last
vic to message the bridge receives the streams.
On 1/30/07 10:53 AM, Joseph Stone wrote:
> I just did a test.  If I bring up "Manage My Node" and Disable the
> VideoConsumerService, wait, and then Enable it again, it gets the
> streams.  Was this just chance or will this work every time?
> Joe
> On Jan 30, 2007, at 2:49 AM, Andrew A Rowley wrote:
>> Hi,
>> If you are using unicast, this is the way in which it works.  Only
>> one of the vic instances can bind to the unicast port, which means
>> that sometimes you will see video in the VideoConsumerService window,
>> and sometimes in the VideoProducerService window.  It is fairly
>> random as to which gets the video.
