[AG-TECH] Re: Compiling VIC in Visual Studio 8 (2005)
    Andrew A Rowley
    Andrew.Rowley at manchester.ac.uk
    Tue Jan 30 02:49:25 CST 2007
If you are using unicast, this is the way in which it works.  Only one of the vic instances can bind to the unicast port, which means that sometimes you will see video in the VideoConsumerService window, and sometimes in the VideoProducerService window.  It is fairly random as to which gets the video.  In any case, the quickbridge process that performs the bridging will never send anything you send back to you, so you will never see your video in the VideoConsumerService window when using unicast.  You should see your video in both windows when using multicast, although this will depend on your networking setup and operating system.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Sam Gundry
> Sent: 30 January 2007 05:21
> To: Piers O'Hanlon
> Cc: vic at cs.ucl.ac.uk; sumover-dev; ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Re: Compiling VIC in Visual Studio 8 (2005)
> Hi Piers,
> Thanks for your feedback, VIC now compiles.
> When I run Access Grid and VIC is invoked, the video image captured from
> my camera is transmitted properly - I can view it in Access Grid on a
> remote machine. Good.
> However, no video thumbnail appears locally. That is, the "Waiting for
> Video" text disappears but no thumbnail appears in the
> VideoConsumerService window.
> I have attached the debug. (I've added a bit of my own output to assist.)
> Video works fine when I replace my own compiled VIC binary with an
> already available binary, VIC v2.8ucl 1.2.1.
> Thanks heaps for any advice or feedback. Below is a description of the
> changes I made to compile VIC in VS8.0.
> Kind regards,
> Sam.
> Changes I made to compile VIC:
> - Added the DirectX SDK include and library paths.
> - Added the command line argument "/FORCE:multiple" to avoid already
> defined linker errors (Is this an issue with the order of libraries
> linked?):
> > 11>LIBCMTD.lib(strtol.obj) : warning LNK4006: _strtol already defined in
> strtol.obj; second definition ignored
> > 11>LIBCMTD.lib(strtol.obj) : warning LNK4006: _strtoul already defined
> in strtoul.obj; second definition ignored
> > 11>LIBCMTD.lib(printf.obj) : warning LNK4006: _printf already defined in
> win32.obj; second definition ignored
> - And commented out a section in the function "find_win32_interface()"
> in "common/src/net_udp.c" to avoid the follow errors (the comments said
> this would have ramifications with RAT, which I don't require at present):
> > 11>uclmm.lib(net_udp.obj) : error LNK2019: unresolved external symbol
> _GetAdaptersInfo at 8 referenced in function _find_win32_interface
> _GetBestRoute at 12 referenced in function _find_win32_interface
> Piers O'Hanlon wrote:
> > On 24/01/07, Sam Gundry <sgundry at vpac.org> wrote:
> >> Hi,
> >> I have obtained VIC, TCL and TK from your CVS repository:
> >> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/vic/trunk
> >> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/tcl-8.0
> >> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/tk-8.0
> >> And now I wish to compile VIC using Visual Studio 8 (since I don't have
> >> any older versions available). When I open "vic.sln", VS automatically
> >> 'converts' it to VS 8.0 format.
> >> However, when I choose to Build "Release" or "Debug" projects, I
> receive
> >> the following errors:
> >> > 8>c:\sgundry\ucl media tools\vic\video\grabber-win32DS.h(33) : fatal
> >> error C1083: Cannot open include file: 'dshow.h': No such file or
> >> directory
> >> > 8>c:\sgundry\ucl media tools\vic\video\crossbar.h(29) : fatal error
> >> C1083: Cannot open include file: 'dshow.h': No such file or directory
> >> > 8>.\main.cpp(73) : fatal error C1083: Cannot open include file:
> >> 'postproc/cpudetect.h': No such file or directory
> >> > 8>.\net\net-ip.cpp(224) : error C2440: '=' : cannot convert from
> >> 'const char *' to 'char *'
> >> > 8>BSCMAKE: error BK1506 : cannot open file '.\release\display.sbr':
> >> - I was wondering if you have any instructions on compiling VIC using
> >> VS8?
> >> - Have you seen these errors before?
> >> - Should VIC compile successfully under VS8?
> >> - Do you have any advice? :(
> > To obtain the dshow.h you need in stall the Direct SDK from Microsoft:
> > http://www.microsoft.com/downloads/details.aspx?familyid=124552FF-8363-
> 47FD-8F3B-36C226E04C85&displaylang=en
> > Try building VIC with the Debug XP profile. Also we've been updating
> > vic recently and it now starting to use the latest version of tcl/tk -
> > which you need to download from the tcl/tk site.
> > Also try getting the latest version using svn.
> > YOu integration project sounds interesting. I will be away for a week
> > but I may be able to hepl when I return if you still have problems. We
> > are in the middle of trying to stablise the tools for next release in
> > a few  weeks so things may be abit messy right now.
> > YOu could also just download the source tar balls for the previuosly
> > released versions.
> > Piers.
> >> For your interest, I am attempting to integrate Access Grid
> >> functionality, such as Video, into Virtools - a 3D graphics
> environment.
> >>    To ensure efficiency, I want to write each video's pixel data from
> >> VIC to shared memory, which I will then read and display inside
> Virtools.
> >> Thanks for any advice or suggestions!
> >> Sam
> >> Centre for Computational Prototyping
> >> Victorian Partnership for Advanced Computing
> >> www.vpac.org
> www.vpac.org
