[AG-TECH] Re: Compiling VIC in Visual Studio 8 (2005)
Sam Gundry
sgundry at vpac.org
Mon Jan 29 23:20:44 CST 2007
Hi Piers,
Thanks for your feedback, VIC now compiles.
When I run Access Grid and VIC is invoked, the video image captured from
my camera is transmitted properly - I can view it in Access Grid on a
remote machine. Good.
However, no video thumbnail appears locally. That is, the "Waiting for
Video" text disappears but no thumbnail appears in the
VideoConsumerService window.
I have attached the debug. (I've added a bit of my own output to assist.)
Video works fine when I replace my own compiled VIC binary with an
already available binary, VIC v2.8ucl 1.2.1.
Thanks heaps for any advice or feedback. Below is a description of the
changes I made to compile VIC in VS8.0.
Kind regards,
Sam.
Changes I made to compile VIC:
- Added the DirectX SDK include and library paths.
- Added the command line argument "/FORCE:multiple" to avoid already
defined linker errors (Is this an issue with the order of libraries
linked?):
> 11>LIBCMTD.lib(strtol.obj) : warning LNK4006: _strtol already defined in strtol.obj; second definition ignored
> 11>LIBCMTD.lib(strtol.obj) : warning LNK4006: _strtoul already defined in strtoul.obj; second definition ignored
> 11>LIBCMTD.lib(printf.obj) : warning LNK4006: _printf already defined in win32.obj; second definition ignored
- And commented out a section in the function "find_win32_interface()"
in "common/src/net_udp.c" to avoid the follow errors (the comments said
this would have ramifications with RAT, which I don't require at present):
> 11>uclmm.lib(net_udp.obj) : error LNK2019: unresolved external symbol _GetAdaptersInfo at 8 referenced in function _find_win32_interface
> 11>uclmm.lib(net_udp.obj) : error LNK2019: unresolved external symbol _GetBestRoute at 12 referenced in function _find_win32_interface
Piers O'Hanlon wrote:
> On 24/01/07, Sam Gundry <sgundry at vpac.org> wrote:
>> Hi,
>> I have obtained VIC, TCL and TK from your CVS repository:
>> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/vic/trunk
>> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/tcl-8.0
>> - http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/tk-8.0
>> And now I wish to compile VIC using Visual Studio 8 (since I don't have
>> any older versions available). When I open "vic.sln", VS automatically
>> 'converts' it to VS 8.0 format.
>> However, when I choose to Build "Release" or "Debug" projects, I receive
>> the following errors:
>> > 8>c:\sgundry\ucl media tools\vic\video\grabber-win32DS.h(33) : fatal
>> error C1083: Cannot open include file: 'dshow.h': No such file or
>> directory
>> > 8>c:\sgundry\ucl media tools\vic\video\crossbar.h(29) : fatal error
>> C1083: Cannot open include file: 'dshow.h': No such file or directory
>> > 8>.\main.cpp(73) : fatal error C1083: Cannot open include file:
>> 'postproc/cpudetect.h': No such file or directory
>> > 8>.\net\net-ip.cpp(224) : error C2440: '=' : cannot convert from
>> 'const char *' to 'char *'
>> > 8>BSCMAKE: error BK1506 : cannot open file '.\release\display.sbr':
>> - I was wondering if you have any instructions on compiling VIC using
>> VS8?
>> - Have you seen these errors before?
>> - Should VIC compile successfully under VS8?
>> - Do you have any advice? :(
> To obtain the dshow.h you need in stall the Direct SDK from Microsoft:
> http://www.microsoft.com/downloads/details.aspx?familyid=124552FF-8363-47FD-8F3B-36C226E04C85&displaylang=en
> Try building VIC with the Debug XP profile. Also we've been updating
> vic recently and it now starting to use the latest version of tcl/tk -
> which you need to download from the tcl/tk site.
> Also try getting the latest version using svn.
> YOu integration project sounds interesting. I will be away for a week
> but I may be able to hepl when I return if you still have problems. We
> are in the middle of trying to stablise the tools for next release in
> a few weeks so things may be abit messy right now.
> YOu could also just download the source tar balls for the previuosly
> released versions.
> Piers.
>> For your interest, I am attempting to integrate Access Grid
>> functionality, such as Video, into Virtools - a 3D graphics environment.
>> To ensure efficiency, I want to write each video's pixel data from
>> VIC to shared memory, which I will then read and display inside Virtools.
>> Thanks for any advice or suggestions!
>> Sam
>> Centre for Computational Prototyping
>> Victorian Partnership for Advanced Computing
>> www.vpac.org
www.vpac.org
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070130/451fc965/attachment.txt>
