[AG-TECH] ag3 install/starting problems
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri Jan 26 14:16:47 CST 2007
Paul:
It looks to be a problem with the version of wxPython.  Which version
is installed on that machine?
Tom
On 1/26/07 12:11 AM, Paul Mercer wrote:
> Tom
> The problem must have been with the downloaded modules.  Today I
> downloaded the modules and burned them to a cd before going over the
> the high school.  I installed them on another workstation and all went
> find and it all worked.  That is except for some network problems that
> will be worked out soon.  I'm not sure about what to do with the other
> workstation.  The uninstaller might not be doing a complete job like
> John said.  I know once I had to rebuild an entire machine to  make it
> install correctly.
> Paul
> On Jan 25, 2007, at 2:41 PM, Paul Mercer wrote:
>> Tom
>> Here are the results of trying to start it from the command line:
>> C:\Program Files\AGTk-3\bin>VenueClient3.py -d
>> Traceback (most recent call last):
>>   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 159, in ?
>>     main()
>>   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 62, in main
>>     wxapp = wxPySimpleApp(clearSigInt=0)
>> TypeError: __init__() got an unexpected keyword argument 'clearSigInt'
>> I hope that this is helpful.
>> Paul
>> On Jan 24, 2007, at 11:22 AM, Thomas D. Uram wrote:
>>> You could try this:
>>> - open a command prompt
>>> - cd c:\program files\agtk-3\bin
>>> - venueclient3.py -d
>>> If the venueclient is not starting, some indication of the problem
>>> should print in the command window.
>>> I'm very curious to hear what it is.
>>> Tom
>>> On 1/24/07 2:06 PM, Paul Mercer wrote:
>>>> All
>>>> I'm having a problem installing ag3 on a win xp box at a local high
>>>> school.  The installation seems to go ok, installing all required
>>>> packages but when I try and start the venue client nothing
>>>> happens.  Looking at the task manager-->processes  I see that
>>>> pythonw.exe starts for a few seconds but then stops.  Logs are
>>>> empty. I have seen this problem before but I installed using a
>>>> non-admin account.  This time I was logged in as an admin.
>>>> firewall is off
>>>> I have uninstalled and downloaded packages again and reinstalled to
>>>> no avail.
>>>> Has anyone else see this problem or knows what is going on?
>>>> thank  you
>>>> Paul Mercer
>>>> Arctic Region Supercomputing Center
>>>> 907 450 8649
>> Paul Mercer
>> 907 450 8649
> Paul Mercer
> 907 450 8649
