[AG-TECH] ag3 install/starting problems
    Paul Mercer
    mercer at arsc.edu
    Fri Jan 26 00:11:38 CST 2007
Tom
The problem must have been with the downloaded modules.  Today I
downloaded the modules and burned them to a cd before going over the
the high school.  I installed them on another workstation and all
went find and it all worked.  That is except for some network
problems that will be worked out soon.  I'm not sure about what to do
with the other workstation.  The uninstaller might not be doing a
complete job like John said.  I know once I had to rebuild an entire
machine to  make it install correctly.
Paul
On Jan 25, 2007, at 2:41 PM, Paul Mercer wrote:
> Tom
> Here are the results of trying to start it from the command line:
> C:\Program Files\AGTk-3\bin>VenueClient3.py -d
> Traceback (most recent call last):
>   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 159, in ?
>     main()
>   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 62, in main
>     wxapp = wxPySimpleApp(clearSigInt=0)
> TypeError: __init__() got an unexpected keyword argument 'clearSigInt'
> I hope that this is helpful.
> Paul
> On Jan 24, 2007, at 11:22 AM, Thomas D. Uram wrote:
>> You could try this:
>> - open a command prompt
>> - cd c:\program files\agtk-3\bin
>> - venueclient3.py -d
>> If the venueclient is not starting, some indication of the problem
>> should print in the command window.
>> I'm very curious to hear what it is.
>> Tom
>> On 1/24/07 2:06 PM, Paul Mercer wrote:
>>> All
>>> I'm having a problem installing ag3 on a win xp box at a local
>>> high school.  The installation seems to go ok, installing all
>>> required packages but when I try and start the venue client
>>> nothing happens.  Looking at the task manager-->processes  I see
>>> that pythonw.exe starts for a few seconds but then stops.  Logs
>>> are empty. I have seen this problem before but I installed using
>>> a non-admin account.  This time I was logged in as an admin.
>>> firewall is off
>>> I have uninstalled and downloaded packages again and reinstalled
>>> to no avail.
>>> Has anyone else see this problem or knows what is going on?
>>> thank  you
>>> Paul Mercer
>>> Arctic Region Supercomputing Center
>>> 907 450 8649
> Paul Mercer
> 907 450 8649
Paul Mercer
907 450 8649
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070125/7abc1180/attachment.htm>
