[AG-TECH] ag3 install/starting problems
    Paul Mercer
    mercer at arsc.edu
    Thu Jan 25 17:41:46 CST 2007
Tom
Here are the results of trying to start it from the command line:
C:\Program Files\AGTk-3\bin>VenueClient3.py -d
Traceback (most recent call last):
   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 159, in ?
     main()
   File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 62, in main
     wxapp = wxPySimpleApp(clearSigInt=0)
TypeError: __init__() got an unexpected keyword argument 'clearSigInt'
I hope that this is helpful.
Paul
On Jan 24, 2007, at 11:22 AM, Thomas D. Uram wrote:
> You could try this:
> - open a command prompt
> - cd c:\program files\agtk-3\bin
> - venueclient3.py -d
> If the venueclient is not starting, some indication of the problem
> should print in the command window.
> I'm very curious to hear what it is.
> Tom
> On 1/24/07 2:06 PM, Paul Mercer wrote:
>> All
>> I'm having a problem installing ag3 on a win xp box at a local
>> high school.  The installation seems to go ok, installing all
>> required packages but when I try and start the venue client
>> nothing happens.  Looking at the task manager-->processes  I see
>> that pythonw.exe starts for a few seconds but then stops.  Logs
>> are empty. I have seen this problem before but I installed using a
>> non-admin account.  This time I was logged in as an admin.
>> firewall is off
>> I have uninstalled and downloaded packages again and reinstalled
>> to no avail.
>> Has anyone else see this problem or knows what is going on?
>> thank  you
>> Paul Mercer
>> Arctic Region Supercomputing Center
>> 907 450 8649
Paul Mercer
907 450 8649
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070125/5f82197c/attachment.htm>
