[AG-TECH] Realtek and rat crashing
George Estes
gestes at ncsa.uiuc.edu
Thu Jan 11 14:18:21 CST 2007
When I try to run the UCL 4.3 RAT from 3.0 I get an address error related to -S. If we comment out the "pass public id as site id" section in AudioService.py the 4.3 RAT runs fine. Do bad things happen elsewhere when we comment out that section?
George
At 11:26 AM 1/11/2007 -0600, Thomas D. Uram wrote:
>A couple comments below...
>On 1/11/07 8:38 AM, Tom Coffin wrote:
>>so - yesterday the soundblaster pcmcia card came and
>>I installed it and am testing it out. Initially, everything
>>was working great - so I left it up over night. When I
>>came in, in the morning, rat had frozen again - as it was
>>doing with the realtech card - I disabled and re-enabled and
>>the freeze came much faster. I then noted that I was
>>still using the rat 4.22... I thought I had copied the latest rat
>>into bin and the zip folder.
>>So, I tried the latest UCL Rat 4.3 solo - when I run that by itself
>>(connecting to one of the NCSA ag3 venues) it works fine
>>so I tried to copy over the rats in bin and in the zip folder again
>>but the venue still starts up a 4.2 version of rat - is
>>there another instance somewhere which I need to copy
>>the new rats into?
>The rat executables are in your ~/.AccessGrid3/local_services/AudioService
>directory (or c:\documents and settings\<you>\accessgrid3\local_services\AudioService.
>There is a command-line compatibility issue between the AG
>rat and the UCL rat, so you can't just drop the UCL rat into
>place. They are planning to fix that by supporting the new option
>in a future release.
>>Also, I notice that the default configuration always lists
>>my video service but it always comes up as disabled - no matter
>>how many times i save the config after enabling
>That setting is in user preferences (tools->preferences->mynode).
>You may have to stretch the window larger, but at the bottom, you'll
>see a checkbox for 'enable video'. Check it and save preferences.
>>At 10:47 AM 1/9/2007, you wrote:
>>>>At 09:57 AM 1/9/2007, George Estes wrote:
>>>>>Thanks Tom,
>>>>> I'm looking at trying a PCI-X card, since I do have an empty PCI-X slot. Either the Sound Blaster X-Fi or the M-Audio card look like possibilities. Although I'm not either will work with RAT.
>>>>>George
>>>>>At 08:45 AM 1/9/2007 -0600, Tom Coffin wrote:
>>>>>>hi George - I had the same problms...
>>>>>>am going to try out the new soundblaster
>>>>>>pcmcia card - if that doesn't work I was
>>>>>>going to try the soundblaster external card which connects
>>>>>>by usb.
>>>>>>I tried updating the rat from UCL and that didn't help
>>>>>>not sure why rat and realtek don't work together
>>>>>>the audio works fine on other apps
>>>>>>On Mon, 8 Jan 2007, George Estes wrote:
>>>>>> > Anyone,
>>>>>> > I see an old thread about RAT crashing with Realtek drivers. Does anyone know if that problem has been fixed? I have a new machine with the latest drivers for an onboard Realtek card and after a period of time RAT becomes unresponsive. Changing venues causes it to become responsive again. Of course it's been running for two hours now without hanging. Has anyone found a solution other than adding another sound card? Or does anyone know of an affordable PCI-X sound card?
>>>>>> > Thanks,
>>>>>> > George
>>>>___________________________________________________________
>>>>Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>>>> NCSA-ACCESS cel: 703-477-5948
>>>> 901 North Stuart Street, #800 tel: 703-248-0105
>>>> Arlington, Virginia 22203 fax: 703-248-0100
>>>>_________________________ http://www.ncsa.uiuc.edu/~tcoffin
