[AG-TECH] Realtek and rat crashing
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Jan 11 11:26:04 CST 2007
A couple comments below...
On 1/11/07 8:38 AM, Tom Coffin wrote:
> so - yesterday the soundblaster pcmcia card came and
> I installed it and am testing it out. Initially, everything
> was working great - so I left it up over night. When I
> came in, in the morning, rat had frozen again - as it was
> doing with the realtech card - I disabled and re-enabled and
> the freeze came much faster. I then noted that I was
> still using the rat 4.22... I thought I had copied the latest rat
> into bin and the zip folder.
> So, I tried the latest UCL Rat 4.3 solo - when I run that by itself
> (connecting to one of the NCSA ag3 venues) it works fine
> so I tried to copy over the rats in bin and in the zip folder again
> but the venue still starts up a 4.2 version of rat - is
> there another instance somewhere which I need to copy
> the new rats into?
The rat executables are in your ~/.AccessGrid3/local_services/AudioService
directory (or c:\documents and
settings\<you>\accessgrid3\local_services\AudioService.
There is a command-line compatibility issue between the AG
rat and the UCL rat, so you can't just drop the UCL rat into
place.  They are planning to fix that by supporting the new option
in a future release.
> Also, I notice that the default configuration always lists
> my video service but it always comes up as disabled - no matter
> how many times i save the config after enabling
That setting is in user preferences (tools->preferences->mynode).
You may have to stretch the window larger, but at the bottom, you'll
see a checkbox for 'enable video'.  Check it and save preferences.
> At 10:47 AM 1/9/2007, you wrote:
>> >At 09:57 AM 1/9/2007, George Estes wrote:
>> >>Thanks Tom,
>> >>  I'm looking at trying a PCI-X card, since I do have an empty
>> PCI-X slot.  Either the Sound Blaster X-Fi or the M-Audio card look
>> like possibilities.  Although I'm not either will work with RAT.
>> >>George
>> >>At 08:45 AM 1/9/2007 -0600, Tom Coffin wrote:
>> >>>hi George - I had the same problms...
>> >>>am going to try out the new soundblaster
>> >>>pcmcia card - if that doesn't work I was
>> >>>going to try the soundblaster external card which connects
>> >>>by usb.
>> >>>I tried updating the rat from UCL and that didn't help
>> >>>not sure why rat and realtek don't work together
>> >>>the audio works fine on other apps
>> >>>On Mon, 8 Jan 2007, George Estes wrote:
>> >>>    > Anyone,
>> >>>    >   I see an old thread about RAT crashing with Realtek
>> drivers.  Does anyone know if that problem has been fixed?  I have a
>> new machine with the latest drivers for an onboard Realtek card and
>> after a period of time RAT becomes unresponsive.  Changing venues
>> causes it to become responsive again.  Of course it's been running
>> for two hours now without hanging.  Has anyone found a solution other
>> than adding another sound card?  Or does anyone know of an affordable
>> PCI-X sound card?
>> >>>    > Thanks,
>> >>>    > George
>> >___________________________________________________________
>> >Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>> >   NCSA-ACCESS                         cel: 703-477-5948
>> >   901 North Stuart Street, #800       tel: 703-248-0105
>> >   Arlington, Virginia 22203           fax: 703-248-0100
>> >_________________________ http://www.ncsa.uiuc.edu/~tcoffin
