so - yesterday the soundblaster pcmcia card came and
I installed it and am testing it out. Initially, everything
was working great - so I left it up over night. When I
came in, in the morning, rat had frozen again - as it was
doing with the realtech card - I disabled and re-enabled and
the freeze came much faster. I then noted that I was
still using the rat 4.22... I thought I had copied the latest rat
into bin and the zip folder.
So, I tried the latest UCL Rat 4.3 solo - when I run that by itself
(connecting to one of the NCSA ag3 venues) it works fine
so I tried to copy over the rats in bin and in the zip folder again
but the venue still starts up a 4.2 version of rat - is
there another instance somewhere which I need to copy
the new rats into?
Also, I notice that the default configuration always lists
my video service but it always comes up as disabled - no matter
how many times i save the config after enabling
At 10:47 AM 1/9/2007, you wrote:
> >At 09:57 AM 1/9/2007, George Estes wrote:
> >>Thanks Tom,
> >> I'm looking at trying a PCI-X card, since I do have an empty PCI-X
> slot. Either the Sound Blaster X-Fi or the M-Audio card look like
> possibilities. Although I'm not either will work with RAT.
> >>George
> >>At 08:45 AM 1/9/2007 -0600, Tom Coffin wrote:
> >>>hi George - I had the same problms...
> >>>am going to try out the new soundblaster
> >>>pcmcia card - if that doesn't work I was
> >>>going to try the soundblaster external card which connects
> >>>by usb.
> >>>I tried updating the rat from UCL and that didn't help
> >>>not sure why rat and realtek don't work together
> >>>the audio works fine on other apps
> >>>On Mon, 8 Jan 2007, George Estes wrote:
> >>> > Anyone,
> >>> > I see an old thread about RAT crashing with Realtek
> drivers. Does anyone know if that problem has been fixed? I have a new
> machine with the latest drivers for an onboard Realtek card and after a
> period of time RAT becomes unresponsive. Changing venues causes it to
> become responsive again. Of course it's been running for two hours now
> without hanging. Has anyone found a solution other than adding another
> sound card? Or does anyone know of an affordable PCI-X sound card?
> >>> > Thanks,
> >>> > George
> >___________________________________________________________
> >Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
> > NCSA-ACCESS cel: 703-477-5948
> > 901 North Stuart Street, #800 tel: 703-248-0105
> > Arlington, Virginia 22203 fax: 703-248-0100
> >_________________________ http://www.ncsa.uiuc.edu/~tcoffin
