[AG-TECH] Listing Venue Server addresses
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Fri Feb 16 07:46:22 CST 2007
The attached script lists the venues in csv format with the audio address and port and the video address and port. You just specify the url of the server on the command line:
ListVenues.py --url=https://your.venue.server:port/VenueServer
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Derek Piper
> Sent: 15 February 2007 17:17
> To: Access Grid Technical mailing list
> Subject: [AG-TECH] Listing Venue Server addresses
> Hi,
> I'm in the process of creating my 'mirrored' venue servers, having
> gathered some addresses (with Andrew Rowley's help I knew what to ask
> the network guys for :))
> One question.. in creating the address/port assignments I made
> myself a
> spreadsheet to keep it all straight, but is there a way to get the venue
> server to dump a list of the configuration of each venue it has for name
> and audio/video host/port. Then anomalies could easily be spotted and I
> can compare outputs of both venue servers to make sure they match.
> While talking about the venue management tool it would be nice to be
> able to restrict it to a single IP address for multicast (and just let
> it dynamically assign ports). As it is, the mask only allows for 0-31,
> where I need '32' in order to lock it down as such. I was given two
> addresses but they do not fit within one /31 CIDR range (of course :>).
> When entering in static addresses, can we have the default TTL be
> 127?
> either filled in automatically or assumed when 0/blank is entered.
> Well, I've rambled on enough about wish-list stuff ;)
> Thanks,
> Derek
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070216/05c6fdf7/attachment.obj>
