[AG-TECH] TFT Display
Natalia Costas
natalia at cesga.es
Sat Feb 10 06:17:15 CST 2007
Ohhh, that's amazing!!! 60" with smartboard, do they use the smartboard
capabilities?.
Brian Corrie escribió:
> Hello,
> We have several rooms with multiple 60" plasmas in them. They are nice
> for all of the reasons you state. We have Smartboards on our plasmas
> so they can be used as interaction devices directly, which changed the
> dynamic of how they are used (in a good way in most cases). As you can
> see from the two rooms (links to pictures below), we use them in quite
> different ways in our environments. Both rooms are AG rooms. The
> second room only has two displays, and therefore we run into the
> anticipated screen real estate issues for large collaborations. It
> works quite well for group to group collaborations between small
> numbers of sites. It would be nice to have three plasmas in Room
> 10901, but then I think slightly smaller plasmas would probably be in
> order (3 52" plasmas would be good for a room in this configuration).
> http://www.irmacs.sfu.ca/facilities/room_10900.php
> http://www.irmacs.sfu.ca/facilities/room_10901.php
> Cheers,
> Brian
> Tom Coffin wrote:
>> In my opinion, the choice of display is dependant
>> upon the size of the room you are using. We use
>> a variety of different displays depending upon
>> the size of the node. 3, 46" TFT screens sounds ideal
>> for a small-medium size room accommodating <10 people.
>> ___________________________________________
>> At 05:25 AM 2/8/2007, Natalia Costas wrote:
>>> Hi everybody,
>>> I was thinking about the idea of replacing the 3proyector+triple
>>> screen by 3 TFT 46" screens (maybe a crazy idea?). The pros i can
>>> think of are:
>>> - No lamps need
>>> - No natural light affects projection.
>>> - No unalignment problem
>>> - Good resolution (in TFTs, not in plasmas)
>>> - Equal price
>>> - HD support (in TFTs, not in plasmas)
>>> The cons I can think of are:
>>> - Projection size
>>> - Mobility
>>> Any other cons?. Has anyone experienced AG with TFTs? How far can be
>>> the screens from the participants? Is it suitable only for meetings
>>> with only a few attendants? (what about classes with around 15-20
>>> pupils?)
>>> Kind regards,
>>> Natalia
>>> Natalia Costas Lago
>>> Técnico de Comunicaciones - Dpto. de Comunicaciones
>>> Centro de Supercomputacion de Galicia (CESGA)
>>> Avenida de Vigo, s/n (Campus Sur)
>>> 15705 Santiago de Compostela - SPAIN
>>> E-mail: natalia at cesga.es
>>> Tel: +34 981 56 98 10 (ext. 237)
>>> Fax: +34 981 59 46 16
>>> Web: http://www.cesga.es/
>> ___________________________________________________________
>> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>> NCSA-ACCESS cel: 703-477-5948
>> 901 North Stuart Street, #800 tel: 703-248-0105
>> Arlington, Virginia 22203 fax: 703-248-0100
>> _________________________ http://www.ncsa.uiuc.edu/~tcoffin
Natalia Costas Lago
