[AG-TECH] Combining 2.4 and 3.0 venue servers
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Tue Feb 6 02:57:09 CST 2007
The reason that you cannot have two bridge servers on the same machine is that QuickBridge disables the return of multicast packets to the sending machine (known as multicast loopback), so packets sent by one bridge cannot be received by the other. If you need to do this, you would need to modify quickbridge. This could cause a looping of packets (it shouldn't do, but I could not have thought of something).
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Thomas D. Uram
> Sent: 05 February 2007 18:45
> To: Jeremy Mann
> Cc: ag-tech
> Subject: Re: [AG-TECH] Combining 2.4 and 3.0 venue servers
> The multicast ports are not actually used by the VenueServer
> machine. They are just passed to the clients who actually
> use the ports.
> Bridges for the two versions should be separated between
> two machines, because I haven't seen reliable transmission of
> content between two bridges running on the same machine.
> On 2/5/07 12:41 PM, Jeremy Mann wrote:
> > Using this method, the 3.0 server would have to be on a seperate
> > machine because I can't start the 3.0 server with the same Multicast
> > ports used with the 2.4 server.
> > On 2/5/07, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> >> The solution we have used for this (and NCSA is using) is to mirror
> >> the Venues across the 2.4 and 3.0 servers. 'Mirroring', in this case,
> >> refers only to the Venue names and structure, and audio/video multicast
> >> addresses; shared applications and data can not be shared between 2.4
> >> and 3.0 clients.
> >> Tom
> >> On 2/5/07 12:01 PM, Jeremy Mann wrote:
> >> > Is there currently a way to have 2.4 and 3.0 clients connect to the
> >> > same virtual venue? The Mac users on campus have upgraded their
> >> > machines and they are all the new duo core Intels which means they
> can
> >> > only install and run the 3.0.x AG client. We still have a majority of
> >> > 2.4 users so telling everybody to upgrade to 3.0.x is pretty much out
> >> > of the question, at least for now.
