[AG-TECH] Combining 2.4 and 3.0 venue servers
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Tue Feb 6 03:03:04 CST 2007
Multicast addresses are fairly sparse, but there are a few ways to go about getting them.
Primarily, people tend to use their GLOP space - this is space that you automatically get assigned when you have been assigned an AS (Autonomous System) number. If your institution or service provider has one of these, you will have 256 multicast addresses that you can use. I would guess that you would speak to your local internet service provider to see if they have AS numbers and ask if you can use the GLOP space.
Failing that, you can apply to IANA for a range of multicast addresses. You will need to make a case for your request however.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Derek Piper
> Sent: 05 February 2007 19:16
> To: Thomas D. Uram
> Cc: Jeremy Mann; ag-tech
> Subject: Re: [AG-TECH] Combining 2.4 and 3.0 venue servers
> Hi,
> I've been wanting to set up this sort of 'combined' venue server.
> How
> do I go about choosing a set of multicast addresses that I can use?
> since they have to be made as statically assigned addresses, yes?
> Derek
> Thomas D. Uram wrote:
> > The multicast ports are not actually used by the VenueServer
> > machine. They are just passed to the clients who actually
> > use the ports.
> > Bridges for the two versions should be separated between
> > two machines, because I haven't seen reliable transmission of
> > content between two bridges running on the same machine.
> > On 2/5/07 12:41 PM, Jeremy Mann wrote:
> >> Using this method, the 3.0 server would have to be on a seperate
> >> machine because I can't start the 3.0 server with the same Multicast
> >> ports used with the 2.4 server.
> >> On 2/5/07, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> >>> The solution we have used for this (and NCSA is using) is to mirror
> >>> the Venues across the 2.4 and 3.0 servers. 'Mirroring', in this case,
> >>> refers only to the Venue names and structure, and audio/video
> multicast
> >>> addresses; shared applications and data can not be shared between 2.4
> >>> and 3.0 clients.
> >>> Tom
> >>> On 2/5/07 12:01 PM, Jeremy Mann wrote:
> >>> > Is there currently a way to have 2.4 and 3.0 clients connect to the
> >>> > same virtual venue? The Mac users on campus have upgraded their
> >>> > machines and they are all the new duo core Intels which means they
> can
> >>> > only install and run the 3.0.x AG client. We still have a majority
> of
> >>> > 2.4 users so telling everybody to upgrade to 3.0.x is pretty much
> out
> >>> > of the question, at least for now.
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
