[AG-TECH] Realtek HD compatible RAT
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Dec 13 18:34:22 CST 2007
Hi Andrew,
> Great work - just tested on my home PC.
Glad to hear it worked.
> Will this code go in to the SUMOVER repository?
Definitely.
> One thing I was wondering was if you could have a selection of input
> and output devices? I don't know if it would actually work, but it
> might then allow Rat to be used with Webcam microphones...
I was originally thinking of providing separate input and output device
support, but settled on doing a simple solution first. In order to
prevent clicks, pops, and other audio artefacts, it's important for
multiple audio cards to be synchronized and not drift apart over time,
for a single audio device this is a non-issue.
> Also, the HD sound cards allow multiple paths - a selectable input and
> output device should allow you to configure based on these paths
(again
> I think this is the case, but I haven't tried out what actually
happens
> here).
For the Realtek HD, I've only seen a single output mixer with multiple
input mixers. I'll be interested to hear if there are HD devices with
more than one output mixer.
Doug
