[AG-TECH] bridge registry
    George Estes
    gestes at ncsa.uiuc.edu
    Fri Aug 24 10:21:33 CDT 2007
  This is great!  Thanks!
At 03:37 PM 8/24/2007 +0100, you wrote:
>Hey folks,
>I've attached the files that allow you to use proxies.
>7.      Copy registryclient.py into
>C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry replacing
>the old one.
>8.      Copy quickbridgeclient.py into
>C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid replacing the old
>one.
>Make sure to make a backup beforehand.
>The proxy host name and port is entered in the preferences on AG.
>Note: this is for AG 3.0.2
>Sambid
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of George Estes
>Sent: 24 August 2007 14:21
>To: Jason Bell
>Cc: ag-tech at mcs.anl.gov
>Subject: RE: [AG-TECH] bridge registry
>Thanks Jason,
>  Is there a workaround to being behind a proxy, other than not being
>behind a proxy?
>George
>At 09:19 AM 8/24/2007 +1000, Jason Bell wrote:
>>George
>>I see this issue some times with other users.  I suggest completely
>>shutting down the VenueClient and then starting it up again, as this
>>does fix the case sometimes.
>>Although, there are occasions such as being behind a "proxy" which
>means
>>the user "currently" will never see the list.
>>Cheers,
>>Jason.
>>From: George Estes [mailto:gestes at ncsa.uiuc.edu]
>>Sent: Friday, 24 August 2007 2:28 AM
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] bridge registry
>>   Is there a port that needs to be open in the firewall to connect to
>>the
>>bridge registry?  I have a user, 3.0.2, who's not seeing any bridges in
>>the
>>list.
>>Thanks,
>>George
