[AG-TECH] node configuration problems with multi-machine node
James Miller
millerjw at psc.edu
Thu Aug 23 14:52:06 CDT 2007
I have an XP display machine which runs the venue client and the node
configuration. My capture box for audio and video is an Ubuntu machine
with 4 Hauppauge cards all identical using the bt878 chipset. I have
multiple video producer services set up using streams /dev/video0
through video3 , but for some reason, when a venue is launched, all 4 of
the capture windows enable the same device (/dev/video3) The
interesting thing is that I can rename the streams in the node
configuration on display, and the stream names make it to the capture
box. For some reason, the ServiceManager just won't open teh proper
device for each stream.
Once the streams are up, I can go to the menu of each stream on the
capture box, and select the proper device which brings up the proper
stream, but it still doesn't remember it's setting when switching venues.
Thoughts?
-Jim
