[AG-TECH] bridge registry
George Estes
gestes at ncsa.uiuc.edu
Fri Aug 24 08:20:32 CDT 2007
Thanks Jason,
Is there a workaround to being behind a proxy, other than not being behind a proxy?
George
At 09:19 AM 8/24/2007 +1000, Jason Bell wrote:
>George
>I see this issue some times with other users. I suggest completely
>shutting down the VenueClient and then starting it up again, as this
>does fix the case sometimes.
>Although, there are occasions such as being behind a "proxy" which means
>the user "currently" will never see the list.
>Cheers,
>Jason.
>-----Original Message-----
>From: George Estes [mailto:gestes at ncsa.uiuc.edu]
>Sent: Friday, 24 August 2007 2:28 AM
>To: ag-tech at mcs.anl.gov
>Subject: [AG-TECH] bridge registry
> Is there a port that needs to be open in the firewall to connect to
>the
>bridge registry? I have a user, 3.0.2, who's not seeing any bridges in
>the
>list.
>Thanks,
>George
