[AG-TECH] AG on >10 displays
    Cindy Sievers
    sievers at lanl.gov
    Thu Aug  2 14:53:55 CDT 2007
Doc,
Are you able to move video between the two screens?  Or do the 2 very wide
screens act independently of each other?  I'm wondering if they behave as
an extended desktop or if they are completely separate of one another.....
Thanks for the info!
Cindy
At 11:45 AM 8/2/2007, Nguyen, Doc Lap wrote:
>Brian,
>    I got it to work using 2 analog TripleHead2Go's on one NVS 440 card
>in a Dell PE2950 Server with dual Intel Xeon Quad cores.  The graphics
>card just thinks there's 2 very wide screens in Windows or Mac.  I
>haven't seen any performance issues with it.  I didn't use all 4 of them
>yet since I didn't have 12 monitors.  I haven't tried it with 2 NVS 440
>cards yet because it only has one PCIe slot, but maybe one day...I'm
>curious how well it'll work..
>   Doc
>-----Original Message-----
>From: Brian Corrie [mailto:bcorrie at sfu.ca]
>Sent: Thursday, August 02, 2007 11:44 AM
>To: Nguyen, Doc Lap
>Cc: Douglas Kosovic; ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] AG on >10 displays
>A couple of comments, questions on this thread...
>Doc, have you tried multiple TripleHead2Go's on a machine with dual
>output on a single card or with on a machine machine with 2 graphics
>cards? When I was looking at this the Matrox docs that I read stated
>that one of these combinations does not work. I think it was the dual
>output on single card hooked up to two TripleHead2Go's.
>Also, related to Chris's previous post. For those that have done this
>(Chris?) how do you find the performance of these cards pushing this
>many pixels, especially when pushing live video to the displays? This
>would be interesting to know if anyone is experimenting with this, as
>one could imagine many possible bottlenecks...
>Cheers,
>Brian
> > Actually, if you use 2 of the Nvidia NVS 440 PCIe x1 quad cards with 8
> > TripleHead2Go's, you'd get 8 * 3 = 24 displays on one computer.  And
> > it works on both Windows and Macs, not sure about Linux...  I've
> > connected
> > 2 of the TripleHead2Go's on a PC and it worked fine, so I expect it
> > should work with 8 of them as well...
> >   Doc
> > *From:* owner-ag-tech at mcs.anl.gov on behalf of Douglas Kosovic
> > *Sent:* Wed 8/1/2007 9:25 PM
> > *To:* ag-tech at mcs.anl.gov
> > *Subject:* Re: [AG-TECH] AG on >10 displays
> > Hi,
> >  > I was wondering if anyone was displaying AG on more than 4
>monitors?
> >  > Maybe on something like a Powerwall set up......what video display
> > cards  > seem to work?  Are you running on several machines?  VGA or
>DVI?
> >  > I suppose I could run several video display machines to avoid a  >
> > performance hit with service managers on each machine....but I thought
> > I'd  > check and see if others are successfully doing this already...
> > How about a PC that has 2 PCI-e x 16 slots filled with high-end PCI-e
> > x 16 video cards, each with 2 x dual-link DVI. Then use 4
> > TripleHead2Go devices to give a total of 12 displays, see following
>for info on TripleHead2Go:
> >   http://www.matrox.com/graphics/en/gxm/products/th2go/
> > I haven't tried it myself, but it would be interesting to see
> > something like that running.
> > Doug
Cindy Sievers           Los Alamos National Laboratory
sievers at lanl.gov        Group CCS-1 MS B287
tel:505.665.6602        Advanced Computing
fax:505.665.4939        Los Alamos, NM 87544
