[AG-TECH] Problem with VenueClient
Eddy Diaz
edd-diaz at uniandes.edu.co
Thu Apr 19 10:31:43 CDT 2007
Hi Douglas, I uninstalled compat-wxPythonGTK2 and now works fine.
Thanks.
Eddy Johel Diaz Murcia edd-diaz at uniandes.edu.co
Estudiante de Maestría en Ingeniería de Sistemas y computación
Asistente graduado del Grupo IMAGINE Universidad de los Andes
Carrera 1 N° 18A-10 Bloque W, Bogotá, Colombia
Laboratorio de Informática Gráfica Teléfono: +57(1) 339 4949 Extensión 3462
-----Mensaje original-----
De: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] En nombre
de Douglas Kosovic
Enviado el: Jueves, 19 de Abril de 2007 08:53 a.m.
Para: Eddy Diaz
CC: ag-tech
Asunto: Re: [AG-TECH] Problem with VenueClient
Hi Eddy,
> I'm working in Fedora core 6. I updated all applications and kernel, now
when
> I start the venue client an error appears.
> [eddy at ginebra ~]$ VenueClient
> Traceback (most recent call last):
> File "/usr/bin/VenueClient", line 22, in ?
> from wxPython.wx import wxPySimpleApp, wxTaskBarIcon, wxICON_ERROR
> ImportError: cannot import name wxTaskBarIcon
> I have installed wxPython-2.6.3.2-2.fc6 and python-2.4.4-1.fc6 versions.
> can you help me?.
I can think of two things that might cause the above error:
Do you have compat-wxPythonGTK2-2.4.2.4 installed? If so issue:
rpm -e compat-wxPythonGTK2
Having wxPython 2.4 installed at the same time as wxPython 2.6 seems to
break wxPython 2.6.
Try issuing the following:
yum list "wx*"
if you are running x86-64 FC6 and see that the installed wx RPMs are
i386 RPMs, that would cause the problem.
Cheers,
Doug
