[AG-TECH] Problem with VenueClient
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Apr 19 08:53:09 CDT 2007
Hi Eddy,
> I'm working in Fedora core 6. I updated all applications and kernel, now when
> I start the venue client an error appears.
> [eddy at ginebra ~]$ VenueClient
> Traceback (most recent call last):
> File "/usr/bin/VenueClient", line 22, in ?
> from wxPython.wx import wxPySimpleApp, wxTaskBarIcon, wxICON_ERROR
> ImportError: cannot import name wxTaskBarIcon
> I have installed wxPython-2.6.3.2-2.fc6 and python-2.4.4-1.fc6 versions.
> can you help me?.
I can think of two things that might cause the above error:
Do you have compat-wxPythonGTK2-2.4.2.4 installed? If so issue:
rpm -e compat-wxPythonGTK2
Having wxPython 2.4 installed at the same time as wxPython 2.6 seems to
break wxPython 2.6.
Try issuing the following:
yum list "wx*"
if you are running x86-64 FC6 and see that the installed wx RPMs are
i386 RPMs, that would cause the problem.
Cheers,
Doug
