[AG-TECH] Capture cards problems, URGENT
Jeremy Mann
jeremymann at gmail.com
Wed Apr 4 12:46:02 CDT 2007
In VIC, when you click on Ports to select Composite, Svideo or Tuner,
the only option I have is external-in. The same if I try and configure
a NodeService. If I use a windows app like AMCAP, I can only select
one card at a time, but I can at least select which port to use.
On 4/4/07, John Hodrien <johnh at comp.leeds.ac.uk> wrote:
> On Wed, 4 Apr 2007, Jeremy Mann wrote:
> > John, I'm in the same predicament here with XP and 2 WinTV capture
> > cards. I've installed the open source drivers, however I can't specify
> > which Composite port to use and it doesn't come up with my 2nd capture
> > card. What is the registry renaming?
> Hmm. I don't have a machine to hand to poke, but I understood that the cards
> had a string that identified them in the registry. Certainly under insors I
> get three with identical names that makes things a little confusing, but I'm
> definitely able to select the port (s-video in my case).
> jh
> "An expert is a man who has made all the mistakes which can be made in a very
> narrow field." -- Neils Bohr
Jeremy Mann
jeremy at biochem.uthscsa.edu
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
