[AG-TECH] Problems bridging 2.4 venue server with FC4 'compat' AG 2.4
Thomas D. Uram
turam at mcs.anl.gov
Mon Sep 18 10:19:11 CDT 2006
Hi Derek:
The URL you've given is for the default venue, not for the venue server.
Try replacing it with:
https://iri-av.informatics.indiana.edu:8000/VenueServer
Tom
On 9/18/06 10:16 AM, Derek Piper wrote:
> Hi Doug et al,
> I have a fedora core 4 machine that I am planning on using as a
> bridge server for both AG2.4 and AG3. I've installed the AccessGrid
> RPMs via the 'yum' method from Doug's repository at vislab. I am
> using the 'compat 2.4' .rpm.
> I have a Bridge server config file pointing to my AG2.4 venue
> server located on an FC5 machine, also running the 3.0 server too. I
> have double-checked the ports are correct and I'm not pointing to
> incompatible versions.
> When running:
> BridgeServer24 -d 3 -c iri-av.cfg
> I get 'GetVenues :exceptions.AttributeError VenueI instance has no
> attribute 'GetVenues'' as an error.
> Pertinant output from bridge server:
> 09/18/06 11:10:25 -1208342848 CertificateManager
> CertificateManager.py:1572DEBUG done, success=1
> 09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:764 INFO
> Initialized Globus.
> 09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:782 INFO Service
> Initialization Complete.
> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:157 INFO
> BridgeFactory.SetPortMin 20000
> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:161 INFO
> BridgeFactory.SetPortMax 40000
> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:259 INFO
> AddVenueServer: url =
> https://iri-av.informatics.indiana.edu:8000/Venues/default
> <Fault SOAP-ENV:Client: Method Not Found: Venues:default:GetVenues :
> exceptions.AttributeError VenueI instance has no attribute 'GetVenues'
> <traceback object at 0xb047e2fc>>
> 09/18/06 11:10:26 -1208342848 Toolkit BridgeServer24:418 ERROR
> Error addingvenue server;
> url=https://iri-av.informatics.indiana.edu:8000/Venues/default
> Traceback (most recent call last):
> File "/usr/bin/BridgeServer24", line 416, in LoadConfig
> self.AddVenueServer(url)
> File "/usr/bin/BridgeServer24", line 262, in AddVenueServer
> venueDescList = VenueServerIW(venueServerUrl).GetVenues()
> File
> "/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/VenueServer.py",
> line 1694, in GetVenues
> vl = self.proxy.GetVenues()
> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 453,
> in __call__
> return self.__r_call(*args, **kw)
> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 475,
> in __r_call
> self.__hd, self.__ma)
> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 389,
> in __call
> raise p
> faultType: <Fault SOAP-ENV:Client: Method Not Found:
> Venues:default:GetVenues :exceptions.AttributeError VenueI instance
> has no attribute 'GetVenues' <traceback object at 0xb047e2fc>>
> Shutting down...
> 09/18/06 11:10:40 -1208342848 Toolkit BridgeServer24:322 INFO
> Method BridgeServer.Shutdown called
> My bridge server config file is:
> [BridgeServer]
> name = Informatics Bridge
> location = Indiana University
> qbexec = /usr/bin/QuickBridge
> BRIDGESERVER = Informatics Bridge
> portMin = 20000
> portMax = 40000
> [https://iri-av.informatics.indiana.edu:8000/Venues/default]
> type = VenueServer
> That venue URL is correct for my venue server. Any
> comments/suggestions?
> Thanks,
> Derek
