[AG-TECH] Problems bridging 2.4 venue server with FC4 'compat' AG 2.4
Derek Piper
dcpiper at indiana.edu
Mon Sep 18 10:44:17 CDT 2006
Ah... thank you much :)
Been a while since I had to set the bridge config file. I managed to
lose the ones I had. That change does indeed work.
Derek
Thomas D. Uram wrote:
> Hi Derek:
> The URL you've given is for the default venue, not for the venue server.
> Try replacing it with:
> https://iri-av.informatics.indiana.edu:8000/VenueServer
> Tom
> On 9/18/06 10:16 AM, Derek Piper wrote:
>> Hi Doug et al,
>> I have a fedora core 4 machine that I am planning on using as a
>> bridge server for both AG2.4 and AG3. I've installed the AccessGrid
>> RPMs via the 'yum' method from Doug's repository at vislab. I am
>> using the 'compat 2.4' .rpm.
>> I have a Bridge server config file pointing to my AG2.4 venue
>> server located on an FC5 machine, also running the 3.0 server too. I
>> have double-checked the ports are correct and I'm not pointing to
>> incompatible versions.
>> When running:
>> BridgeServer24 -d 3 -c iri-av.cfg
>> I get 'GetVenues :exceptions.AttributeError VenueI instance has no
>> attribute 'GetVenues'' as an error.
>> Pertinant output from bridge server:
>> 09/18/06 11:10:25 -1208342848 CertificateManager
>> CertificateManager.py:1572DEBUG done, success=1
>> 09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:764 INFO
>> Initialized Globus.
>> 09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:782 INFO Service
>> Initialization Complete.
>> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:157 INFO
>> BridgeFactory.SetPortMin 20000
>> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:161 INFO
>> BridgeFactory.SetPortMax 40000
>> 09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:259 INFO
>> AddVenueServer: url =
>> https://iri-av.informatics.indiana.edu:8000/Venues/default
>> <Fault SOAP-ENV:Client: Method Not Found: Venues:default:GetVenues :
>> exceptions.AttributeError VenueI instance has no attribute 'GetVenues'
>> <traceback object at 0xb047e2fc>>
>> 09/18/06 11:10:26 -1208342848 Toolkit BridgeServer24:418 ERROR
>> Error addingvenue server;
>> url=https://iri-av.informatics.indiana.edu:8000/Venues/default
>> Traceback (most recent call last):
>> File "/usr/bin/BridgeServer24", line 416, in LoadConfig
>> self.AddVenueServer(url)
>> File "/usr/bin/BridgeServer24", line 262, in AddVenueServer
>> venueDescList = VenueServerIW(venueServerUrl).GetVenues()
>> File
>> "/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/VenueServer.py",
>> line 1694, in GetVenues
>> vl = self.proxy.GetVenues()
>> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 453,
>> in __call__
>> return self.__r_call(*args, **kw)
>> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 475,
>> in __r_call
>> self.__hd, self.__ma)
>> File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 389,
>> in __call
>> raise p
>> faultType: <Fault SOAP-ENV:Client: Method Not Found:
>> Venues:default:GetVenues :exceptions.AttributeError VenueI instance
>> has no attribute 'GetVenues' <traceback object at 0xb047e2fc>>
>> Shutting down...
>> 09/18/06 11:10:40 -1208342848 Toolkit BridgeServer24:322 INFO
>> Method BridgeServer.Shutdown called
>> My bridge server config file is:
>> [BridgeServer]
>> name = Informatics Bridge
>> location = Indiana University
>> qbexec = /usr/bin/QuickBridge
>> BRIDGESERVER = Informatics Bridge
>> portMin = 20000
>> portMax = 40000
>> [https://iri-av.informatics.indiana.edu:8000/Venues/default]
>> type = VenueServer
>> That venue URL is correct for my venue server. Any
>> comments/suggestions?
>> Thanks,
>> Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
